Passenger side door problems #863720 01/25/08 12:36 AM
VanillaTHUNDA Offline OP
87 4runner SR5
It would seem that my passenger side door won't open from the inside using the regular handle. However, it will open when using the rear handle. I pulled off the door panel and it looks like the rod simply doesn't pull enough. Is there an adjustment?
Re: Passenger side door problems [Re: VanillaTHUNDA] #863721 01/25/08 02:46 AM
Cholltero Offline
The rod that attaches to the front handle may have rattled off---------or it is just a little too long to unlatch things in which case you just bend it a little to shorten it up
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Passenger side door problems [Re: VanillaTHUNDA] #863722 01/25/08 05:38 AM
missouriman Offline
look, there is a sort of Z in the rod.. you bend it. or you lost the inside of one of those fold over snap down rod clips.
Re: Passenger side door problems [Re: missouriman] #863723 01/25/08 03:52 PM
G
Greg_Canada Offline
Mine does the same thing some times, if you push on the door panel it works fine.
The main problem is, the rod is flexing and not pulling the latch. Take the panel off and bend the rod, thus making it shorter, it will fix your problems.
89 4Runner
Re: Passenger side door problems [Re: Greg_Canada] #863724 01/26/08 07:19 AM
Problem solved- just bent the rod a bit. Thanks, guys!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6052 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-06-10 07:28:22 UTC
