Loaded calipers - yes/no? #863913 01/26/08 12:11 AM
fire4effect Offline OP
I need to do my front brakes soon.
My 4runner has 370+K on it and I've never replaced the calipers. I read a post awhile back and someone suggested just getting loaded calipers. I never heard of that before, but after looking into I may go that route.
Just wanted to get opinions, before I started buying parts.
Semper Fi,
Alfred
'91 4Runner V6 4WD 400+K
'10 Scion Xb
Re: Loaded calipers - yes/no? [Re: fire4effect] #863914 01/26/08 12:12 AM
87Toy4x4 Offline
loaded calipers just means they come w/ pads. do you need new pads?
Re: Loaded calipers - yes/no? [Re: fire4effect] #863915 01/26/08 12:14 AM
Adam F Offline
Do the calipers stick or something? No need to replace brake parts based soley on mileage. If they are not sticking or leaking, keep them.
97 4R, stock, daily driver
Re: Loaded calipers - yes/no? [Re: Adam F] #863916 01/26/08 04:37 AM
Snowtoy Offline
You can also buy new seals and rebuild them yourself, providing the rest of parts are good.
Re: Loaded calipers - yes/no? [Re: 87Toy4x4] #863917 01/26/08 08:08 PM
Yeah, I need to replace the rotors (no turns left) and pads and was trying to be proactive. I don't see any leaking, but really didn't want to wait.
Sounds like 'no' on loaded calipers.
Semper Fi,
Alfred
'10 Scion Xb
Re: Loaded calipers - yes/no? [Re: fire4effect] #863918 01/26/08 10:07 PM
Adam F Offline
You'll want to replace the pads with the rotors.
If there are no leaks, and you can compress the piston back into the caliper without too much effort, no need for new calipers.
Re: Loaded calipers - yes/no? [Re: fire4effect] #863919 01/27/08 08:58 PM
missouriman Offline
I would replace them. I have had many stick after replacing the rotors. I am not sure if the piston wears a bit or what. I have done the kits. if there is any (catch) when you are compressing them you will be replaceing them and the shoes, possibly the rotors in about 6 months to a year.
just my .02 they are cheap and easy to replace now.
Re: Loaded calipers - yes/no? [Re: missouriman] #863920 01/28/08 10:17 PM
Bustedback Offline
Replacing the calipers is more cost effective than rebuilding them, and a whole lot easier too. I picked up a pair from NAPA for $50 each plus the core charge. I'm not sure what the cost of a rebuild kit is, but I bet it almost half the cost of new calipers.
Re: Loaded calipers - yes/no? [Re: Bustedback] #863921 01/29/08 12:18 AM
Adam F Offline
Rebuild kit is $4. Rebuilding them is simple. Remove the caliper and pop the piston out by either grabbing it with a pliers, or using compressed air in the brake line. Remove the old dust boot and o ring. Clean everything up really good, reinstall dust boot and o ring, reinsall piston, and your done. 15 minutes of work at the most.
Re: Loaded calipers - yes/no? [Re: Adam F] #863922 01/29/08 01:57 AM
KiwiCowboy Offline
What I use to determine if I need to replace calipers is to inspect the cylinder bore for pitting, wear, etc. If there's a lot of pitting, then replace them, otherwise, I clean them up and install a rebuild kit.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6407 MB (Peak: 0.7600 MB) Data Comp: Off Server Time: 2026-10-24 07:17:51 UTC
