Stopping the engine #863947 01/26/08 01:20 AM
L
Littlewhitepup Offline OP
When I shut my truck off it like dies out rough like the motor is still trying to run. It doesn't take long like it stays running its just like still turning. My other cars I have had shut down smooth. Just wondering if anyone knows. Thanks
Re: Stopping the engine [Re: Littlewhitepup] #863948 01/26/08 03:48 PM
Jim_Paget Offline
Typically this is caused by carbon buildup in the cylinders or a timing issue.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Stopping the engine [Re: Jim_Paget] #863949 01/27/08 01:27 AM
L
So is it a big deal? I have the timing pretty good. So im assuming its the carbon.
Re: Stopping the engine [Re: Littlewhitepup] #863950 01/27/08 07:44 AM
2
2002trooper4me Offline
I had the same problem years ago in a Bronco. I just got in the habit of leaving it in drive when I killed the ignition, then shifting to park before removing the key. It obviously didn't fix the carbon problem but the engine stoped dieseling. This might buy you time till you can properly address the issue.
Good Luck!
"If you think you hate it now, just wait till you drive it!"
Mike M.
Richmond, Va
2002 Trooper, stock for now...
2002 Taurus Wagon "The Family Truckster"
Re: Stopping the engine [Re: 2002trooper4me] #863951 01/27/08 07:48 AM
FSJ1978 Offline
Not to muddy the waters but I seem to recall seeing posts about the 2.6L (if that's the engine in your truck) having the ballancer 'slipping' so the timing marks aren't right.
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust)
....(SOA / Custom rear bumper / CB / HAM)
Re: Stopping the engine [Re: FSJ1978] #863952 01/28/08 01:46 PM
L
No its a 2.3l and if its not a hugh problem then I'm not worried about it.
Re: Stopping the engine [Re: Littlewhitepup] #863953 01/30/08 04:55 AM
A
acy76 Offline
I've had older engines act this way. I always used to put it in a high gear (4th or 5th) and let the clutch out. Stopped it right away.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6170 MB (Peak: 0.6902 MB) Data Comp: Off Server Time: 2026-05-29 19:58:40 UTC
