Stopping the engine
#863947
01/26/08 01:20 AM
When I shut my truck off it like dies out rough like the motor is still trying to run. It doesn't take long like it stays running its just like still turning. My other cars I have had shut down smooth. Just wondering if anyone knows. Thanks
Re: Stopping the engine
[Re: Littlewhitepup]
#863948
01/26/08 03:48 PM
Typically this is caused by carbon buildup in the cylinders or a timing issue.
[Re: Jim_Paget]
#863949
01/27/08 01:27 AM
So is it a big deal? I have the timing pretty good. So im assuming its the carbon.
#863950
01/27/08 07:44 AM
I had the same problem years ago in a Bronco. I just got in the habit of leaving it in drive when I killed the ignition, then shifting to park before removing the key. It obviously didn't fix the carbon problem but the engine stoped dieseling. This might buy you time till you can properly address the issue.
Good Luck!
"If you think you hate it now, just wait till you drive it!"
Mike M. Richmond, Va 2002 Trooper, stock for now... 2002 Taurus Wagon "The Family Truckster"
[Re: 2002trooper4me]
#863951
01/27/08 07:48 AM
Not to muddy the waters but I seem to recall seeing posts about the 2.6L (if that's the engine in your truck) having the ballancer 'slipping' so the timing marks aren't right.
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust) ....(SOA / Custom rear bumper / CB / HAM)
[Re: FSJ1978]
#863952
01/28/08 01:46 PM
No its a 2.3l and if its not a hugh problem then I'm not worried about it.
#863953
01/30/08 04:55 AM
I've had older engines act this way. I always used to put it in a high gear (4th or 5th) and let the clutch out. Stopped it right away.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6163 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-05-29 19:58:20 UTCValid HTML 5 and Valid CSS
