Heater fan dead - common causes? #865044 01/29/08 10:37 PM
W
WomBAT Man Offline OP
While I'm at it w/ the flurry of postsàare there any common failure causes for a TII to have its fan (for heater/defroster, etc) suddenly stop?
I'm hoping the answer is something other than tearing apart the dash. <img src="/forums/images/graemlins/scared.gif" alt="" />
'89 T2, TLo, 3.4L, 2ARBs, 5.38s, 35 MTR's, snorkel by Ace Hardware, spare lollipops for li'l wheelers, anti-aero by devo-lution?and no diet in sight.
Re: Heater fan dead - common causes? [Re: WomBAT Man] #865045 01/30/08 02:09 PM
BigSwede Offline
Try it on High setting first. If it runs, then the resistor pack (which regulates all fan speeds except for High, which is straight 12V) is bad. If it doesn't run, check the fuse. If no problem there, the motor is suspect.
Serenity now!
Re: Heater fan dead - common causes? [Re: BigSwede] #865046 01/30/08 07:05 PM
Craig Offline
If you find you need parts, I have a 2.8 Trooper sitting at my place.
Buy a Trooper. You'll be glad you did.
Re: Heater fan dead - common causes? [Re: Craig] #865047 01/31/08 12:31 AM
W
Your Troopers are all full of nasty stingie wasps. If you'd broom the snow off them and dig out the motor for me that would be so very kind of you.
BTW, you old Norwegian woodstove is about to find a home in the shop going in behind my garage. You'll be receiving an invite for the innagural lighting of it (the stove, I mean).
Swede, I'll check. I am 99.9% sure it is dead on all settings though. Fuse is next. IIRC the ones under the hood don't specifiy any as fan/heater, so will have to look up which one it isà
Re: Heater fan dead - common causes? [Re: WomBAT Man] #865048 01/31/08 04:24 AM
JLEMOND Offline
SEAN CHECK THE RELAY UNDER THE LFT FRT HEAD LIGHT , IT IS WHERE THE HEATER BLOWER GETS IT S POWER FROM, IT IS IN A LITTLE PLASTIC RUBBERY CVR USUALLY FULL OF COROSION JERRY
Re: Heater fan dead - common causes? [Re: JLEMOND] #865049 01/31/08 07:36 PM
W
Thanks, Jerry. Will do (once the blizzard stops)
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6102 MB (Peak: 0.6800 MB) Data Comp: Off Server Time: 2026-07-16 13:25:43 UTC
