still trying to hook up my alternator in 86 Trooper TD (more pics) #865295 01/30/08 08:21 PM
bobbybilly Offline OP
i just bought a new alternator and the three wires that connect from the alternator to the wiring harness are not matching colors. The wires coming from the fuse box are a solid white, a white with red stripe and a black with yellow stripe. The wires from the alternator that go into the back of the couple are a solid white, a white with blue stripe and a white with a green stripe
Three wires coming from fuse box
http://i197.photobucket.com/albums/aa166/billyahl/Picture126.jpg
Three wires going into connector from new alternator
http://i197.photobucket.com/albums/aa166/billyahl/Picture145.jpg
I bought a service manual for it. but they do not mention anything about the color of the wires. The wires coming from the wiring harness are original. i am hoping that they would be the same color on all the 86 trooper TD's. If anyone can look at the three small wire set that goes from the fuse box to the alternator and tell me which of theses wires are plugged in to each of the three connectors.
Pic of connector coming from new alternator
http://i197.photobucket.com/albums/aa166/billyahl/Picture128.jpg
Pics of wires from fuse box after new conn. were added
http://i197.photobucket.com/albums/aa166/billyahl/Picture156.jpg
Service manual illistration
http://i197.photobucket.com/albums/aa166/billyahl/Picture160.jpg
Any Help would be greatly appreciated.
Re: still trying to hook up my alternator in 86 Trooper TD (more pics) [Re: bobbybilly] #865296 01/31/08 04:51 AM
overland47 Offline
I am up against the same thing with my conversion. I don't know why isuzu didn't put any colors in their wiring diagrams. I have the factory service manuals, and nothing <img src="/forums/images/graemlins/frown.gif" alt="" />
I am going to get it figured out this weekend and I'll let you know though. I think I can figure out what wire is what with my voltmeter.
One should be the exciter (keyed power), probably the larger of the three. One should be the feild, and the other is probably for the dash light.
Re: still trying to hook up my alternator in 86 Trooper TD (more pics) [Re: overland47] #865297 01/31/08 05:12 AM
A
acy76 Offline
Are you using the factory Electrical Troubleshooting Manual or the service manual (assuming there are separate manuals for your application; there are for the Trooper I've got)? The ETM has all the wiring information you'll ever need, information the service manual glosses over or omits entirely.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: still trying to hook up my alternator in 86 Trooper TD (more pics) [Re: bobbybilly] #865298 01/31/08 05:39 PM
codysin Offline
if you still havent got it run to a altinator place they may be able to help you or you can have then switch the electronics on it to just have one lead that goes strait to your battery i had to have my altinator upgraded due to having a 1750w sterio was to much for the old one and the guy just put a regulator with a lead thats strait to + on battery
Re: still trying to hook up my alternator in 86 Trooper TD (more pics) [Re: bobbybilly] #865299 02/04/08 07:33 AM
overland47 Offline
I thought I'd answer your question here, just 'cause it might help someone else. The alternator wiring looks to be this way:
Chassis/Alternator connector
Black-white/Black-white ... Ignition (might be black-yellow since it's very dirty)
White/White ... 12 V battery
White-Green/White-Red ... measures 86 ohms - charge relay
Hope that helps.
Taken from another post on my conversion.....might help you.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6093 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-10-24 04:20:06 UTC
