failed smog/need help/ #865483 01/31/08 07:46 AM
rodeo08 Offline OP
hi
I had taken my 96' 3.2 rodeo to get a smog test,but it failed . Several trouble codes had come up like: p0137
p0143 p1171 p1406
Does anybody know what these mean and how much they cost to fix?
thanks
Re: failed smog/need help/ [Re: rodeo08] #865484 01/31/08 08:26 AM
Scott F. Offline
1037 & 0143 - Fuel Air Metering
1170 - Manufacture control fuel air metering
1406 - EGR
It sounds like a stuck/clogged EGR, or it simply could need to be replaced. I have never needed to repair/replace mine but it doesn't appear to be difficult to replace, or all that expensive ($100-200). You are also able to clean the EGR but agian I've never done this.
I'm sure someone that has worked on an EGR will chime in.
Scott F.
1995.5 Rodeo V6 Auto
Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: failed smog/need help/ [Re: Scott F.] #865485 02/01/08 06:35 AM
rodeo08 Offline OP
I have a k&n in the airbox.Could that cause the fuel air metering problem?
I had a new egr installed about 3-4 years ago.Do they go bad that often?
thx
Re: failed smog/need help/ [Re: rodeo08] #865486 02/01/08 10:49 PM
BigSwede Offline
Sometimes the oil from the K&N will get on the MAF sensor (if yours has one, can't tell what year yours is) and mess it up. Worth a try to spray it with some carb cleaner...
Serenity now!
Re: failed smog/need help/ [Re: BigSwede] #865487 02/02/08 04:26 AM
2
2002trooper4me Offline
Steve is right. K&N's if over oiled can cause issues.
Good Luck!
"If you think you hate it now, just wait till you drive it!"
Mike M.
Richmond, Va
2002 Trooper, stock for now...
2002 Taurus Wagon "The Family Truckster"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6065 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-06-17 11:45:47 UTC
