failed smog/need help/
#865483
01/31/08 07:46 AM
hi I had taken my 96' 3.2 rodeo to get a smog test,but it failed . Several trouble codes had come up like: p0137 p0143 p1171 p1406 Does anybody know what these mean and how much they cost to fix? thanks
Re: failed smog/need help/
[Re: rodeo08]
#865484
01/31/08 08:26 AM
1037 & 0143 - Fuel Air Metering 1170 - Manufacture control fuel air metering 1406 - EGR
It sounds like a stuck/clogged EGR, or it simply could need to be replaced. I have never needed to repair/replace mine but it doesn't appear to be difficult to replace, or all that expensive ($100-200). You are also able to clean the EGR but agian I've never done this.
I'm sure someone that has worked on an EGR will chime in.
Scott F.
1995.5 Rodeo V6 Auto Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Scott F.]
#865485
02/01/08 06:35 AM
I have a k&n in the airbox.Could that cause the fuel air metering problem? I had a new egr installed about 3-4 years ago.Do they go bad that often? thx
[Re: rodeo08]
#865486
02/01/08 10:49 PM
Sometimes the oil from the K&N will get on the MAF sensor (if yours has one, can't tell what year yours is) and mess it up. Worth a try to spray it with some carb cleaner...
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: BigSwede]
#865487
02/02/08 04:26 AM
Steve is right. K&N's if over oiled can cause issues.
Good Luck!
"If you think you hate it now, just wait till you drive it!"
Mike M. Richmond, Va 2002 Trooper, stock for now... 2002 Taurus Wagon "The Family Truckster"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6045 MB (Peak: 0.6684 MB) Data Comp: Off Server Time: 2026-06-22 14:16:23 UTCValid HTML 5 and Valid CSS
