CV joint #865495 01/31/08 08:21 AM
codysin Offline OP
My dad gave me his 90 Isuzu pickup 2.6l ls as a present for geting my licence and well 2 days after the front left cv joint broke its been clicking for a wile anyone care to give me some insite about how to get the darn thing off? i have got as far as poping the ball joints off were do i go next? any help will be greatly apriciated!
Re: CV joint [Re: codysin] #865496 01/31/08 08:39 AM
Scott F. Offline
Short version.
-remove retaining c-clip inside hub (at end of splines)
-remove brake caliper
-support lower a arm with jack and pop upper ball joint (be sure truck is on stands first)
-lower jack fully and pop off the CV boot from the upper cup
-now remove a retaining ring just inside the upper cup (its hard to see, run your finger just inside the cup ans you should feel it. pop it with a screw driver.
-you should be able to pull it free (I say should because mines a rodeo, don't know pups)
GL
Scoot f.
1995.5 Rodeo V6 Auto
Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: CV joint [Re: Scott F.] #865497 01/31/08 08:43 AM
codysin Offline OP
there is a hard metal "cup" and then goes this suport that side of the diferential so its cup brace transfercase and between brace and transfer case theres the clips but do i have to drop the transfer case to move it over to access these clips or what?
Re: CV joint [Re: codysin] #865498 01/31/08 09:02 AM
Scott F. Offline
OK maybe we are talking about two seperate things. Did you snap an axle (as in between the CV joint and differential)?
Or did you break a CV joint?
The CV joint is easy, like I said. You simply need to remove a clip that is just inside the lip of the upper CV cup. That should free the CV joints.
But if you snapped the axle inside the tube then I believe you need to drop the front assembly (diff, mounts and CVs).
Here is an article about replacing the boots, but it discribes the same process.
CLICK HERE
Scott f.
Re: CV joint [Re: Scott F.] #865499 01/31/08 09:10 AM
codysin Offline OP
i broke the outer cv joint but when i went to purchase a new one they ordered the hole shaft with inner + outer joints and the shaft that goes in the tube there is two groves on the new shaft im asuming are for clips that would sit just inside of the end of the tube how do i get to those?
Re: CV joint [Re: codysin] #865500 01/31/08 09:23 AM
Scott F. Offline
If you wanted to remove the whole assembly, I believe you need to remove the diffcover and remove some clips on the axle. These should be inside the carrier so it is difficult and even then you couldn't just remove the axle. You then need to remove the mounting harware on that side and some pressed fittings. I hae never done this so its beyond me but its not a simple task to remove the front axle assembly.
My sugestion is to return the axle you bought at the store and find a local Pick-n-pull. The just remove the CV axle from a comparable vehicle, cost less, less work and probably better than an after market axle.
Somone with experience with removing the whole front will pobably chime in and help you out on that.
Scott F.
Re: CV joint [Re: codysin] #865501 01/31/08 12:39 PM
strawmyers Offline
Isuzu Moderator
The link Scott posted is great for changing the outer portion of the axle. I would read it first to get an idea of how the hub/spindle/axle assembly goes together. Then, if you are wanting to replace the entire axle all the way up to the differential, you can get an idea of what needs doen in THIS write-up. You won't be installing the drop diff brackets (so no cutting up the crossmember or anything); but the overall process is the same as far as disassembly. The aftermarket shafts aren't really celebrated for their durability when compared to the OEM pieces.
What were you doing when the axle broke? They should see no stress whatsoever when you are in 2wd.
Sean Strawmyer
Re: CV joint [Re: strawmyers] #865502 01/31/08 03:56 PM
codysin Offline OP
i was driving like 5mph on a foot of snow in 4wd and it just gave out
Re: CV joint [Re: codysin] #865503 02/03/08 09:29 AM
codysin Offline OP
any one know what the seal is called thats at the bracket ? i riped mine and have to get a new one but dont know what its called
Re: CV joint [Re: codysin] #865504 02/03/08 04:10 PM
strawmyers Offline
Isuzu Moderator
Inner axle seal. Call St Charles and talk to Merlin. He'll understand what you need and get you the part for a fair price: 1-800-727-8066
Sean Strawmyer
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6362 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-06-22 10:11:47 UTC
