Re: CV joint [Re: strawmyers] #865505 02/03/08 06:54 PM
codysin Offline OP
i have one on the way only like 8$ get it tuesday
Re: CV joint [Re: codysin] #865506 02/06/08 12:27 AM
codysin Offline OP
The seal was the wrong one that came in it was one i found on the internet no part stores have a listing of that seal for a 90 pickup but they can get that seal for a 88 -90 trooper you guys think it will be the same seal? is it worth a shot?
Re: CV joint [Re: codysin] #865507 02/06/08 03:37 AM
strawmyers Offline
Isuzu Moderator
Its worth a shot to call the number I gave you above. They are an Isuzu dealership; so they'll know and have (or be able to drop ship you) exactly what you need.
Sean Strawmyer
Re: CV joint [Re: strawmyers] #865508 02/06/08 06:12 AM
codysin Offline OP
im 16 i have no credit card so no way to order over phone or internet im kinda sol if i cant get it localy
Re: CV joint [Re: codysin] #865509 02/06/08 04:05 PM
mlclark Offline
Isuzu Moderator
Easy fix.
Go to the store. Get yourself a VISA gift card thingys. Put some $$ on it and call St. Charles. They will get you set up.
Michael
Re: CV joint [Re: mlclark] #865510 02/06/08 05:49 PM
codysin Offline OP
didnt think of that :P but theres no place that has visa gift cards for like 50 miles <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: CV joint [Re: codysin] #865511 02/06/08 07:52 PM
mlclark Offline
Isuzu Moderator
If you have to hitch up the wagon and go 50 miles for a gift card, I can promise you will not find this seal locally.
Michael
Re: CV joint [Re: mlclark] #865512 02/06/08 07:56 PM
mlclark Offline
Isuzu Moderator
That seal is an Isuzu seal. You will not probably not find a cross reference for it. I.e. Parts stores will not have this part.
Just so we are all clear, to remove the entire axle, it comes off with the bracket attached to it. The seal and bearing are retained with two c-clips. You cannot remove those clips without pulling everything out. If you pull on the axle, you will destroy that seal. As, I think you have discovered.
Michael
Re: CV joint [Re: mlclark] #865513 02/06/08 08:28 PM
codysin Offline OP
i got the first clip off then the bearing then i couldnt see the other clip and the weight of the diferential on the bracket pinched the seal and cut it thats what happened but they did manage to find the seal for me i have it siting in my hand so local parts store can get it you just have to find the number for them :P i get to go fix it in a hour
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6305 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-06-07 07:18:52 UTC
