Do I need new hubs???? help! #865655 02/01/08 02:15 AM
StarrStuntz Offline OP
I just got a 94 deluxe 4x4 and it seems to have a problem with the front hubs. The transmissions work fine but i'm not sure the hubs are locking when i turn them to lock,, (the front wheels dont have power still)?? do i just need to rebuild my hubs?? any help would be awesome! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Do I need new hubs???? help! [Re: StarrStuntz] #865656 02/01/08 02:24 AM
Adam F Offline
Only way to tell for sure is to put all 4 wheels up on jackstands and put the truck in 4wd and see if the wheels spin. Or you could find a mudhole and see if the fronts pull.
Its pretty common for the hubs to be assembled wrong or for the spring to break. I have links to rebuild how-to's on my site
http://staff.4x4wire.com/adamf/88/hubrebuild.htm
97 4R, stock, daily driver
Re: Do I need new hubs???? help! [Re: Adam F] #865657 02/01/08 02:26 AM
OOP'S Offline
Here is another link to rebuilding them, it is from a 93 FSM.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/suspensionandaxle/14freewhee.pdf
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Do I need new hubs???? help! [Re: Adam F] #865658 02/02/08 12:53 AM
ya, i do know that they dont spin, checked it in the snow.. so looks like i'll just have to rebuild, thanks abunch!
Re: Do I need new hubs???? help! [Re: StarrStuntz] #865659 02/02/08 01:36 AM
RatLabGuy Offline
FYI, you shouldn't have to jack up all 4 tires, just the front 2.
You have manual hubs on a 94? must have been converted from the ADDs? If it's manual, just turn teh tires and see if the CV spins. If it's the ADD, you'll have to see if the other tire spins the other direction.
Or... my favorite... pull the rear driveshaft, engage the case, and see if you can move! (just be prepared to turn it OFF before unengaging the t-case if you don't, lol.)
Question Reality.
Re: Do I need new hubs???? help! [Re: RatLabGuy] #865660 02/02/08 01:41 AM
Adam F Offline
Hows that? As soon as you put it into gear, the rear wheels will have power and it will jump off the jackstands.
Re: Do I need new hubs???? help! [Re: Adam F] #865661 02/02/08 02:10 AM
ya i dont get it either? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Do I need new hubs???? help! [Re: StarrStuntz] #865662 02/02/08 03:40 AM
Scerb Offline
Just jack up the front and try to spin the front tires in the air by hand, with the hubs locked, tranny in gear, xfer in 4lo, etc.
Re: Do I need new hubs???? help! [Re: Scerb] #865663 02/02/08 05:16 AM
ya, they do spin.
Re: Do I need new hubs???? help! [Re: StarrStuntz] #865664 02/02/08 09:37 AM
DRTDEVL Offline
While doing that, look to see if the C/Vs are spinning at the same time...
Could always end up being a transfer case issue.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6396 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-06-07 09:46:49 UTC
