22R carbie throttle control #865669 02/01/08 03:42 AM
kewlynx Offline OP
Someone had posted this awhile back, but I could only find the image. This is a throttle control for a carbie. Post up if you did this install; Adam? Scerb maybe? I'll be putting this one in the archives.
**ubi apis- ibi salus**
Re: 22R carbie throttle control [Re: kewlynx] #865670 02/01/08 03:46 AM
Scerb Offline
Twasn't me.. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: 22R carbie throttle control [Re: kewlynx] #865671 02/01/08 03:54 AM
rondog Offline
I have a 84 truck with a 22R in it. Did you need to know something or pics.I will try to help ya out. Let me know. Ron
Re: 22R carbie throttle control [Re: rondog] #865672 02/01/08 03:58 AM
kewlynx Offline OP
Nope. <img src="/forums/images/graemlins/smile.gif" alt="" /> If you've got pics with one of these installed, that would be pretty cool. Format for pics is in our FAQ above.
Re: 22R carbie throttle control [Re: kewlynx] #865673 02/01/08 07:18 AM
stock87 Offline
I posted that, it's one half of the factory hand throttle setup on diesel trucks. You'd need the pedal assembly and the cable setup to make it work. Nope, never tried it. Always been too poor to do anything but fix the occasional thing that breaks.
Here's the full pic:
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 22R carbie throttle control [Re: stock87] #865674 02/01/08 07:28 AM
Scerb Offline
Factory hand throttle?? Why the hell did toyota do that? Cool though!
Re: 22R carbie throttle control [Re: Scerb] #865675 02/01/08 07:44 AM
kewlynx Offline OP
IIRC, only the early 22RE's had a stock cruise system as part of the SR5 package; my 87 xcab has one.
Stock87, AWESOME. Thanks for adding to it; you da man. <img src="/forums/images/graemlins/cheers.gif" alt="" />
If you set your carb up with a fuel pump for steep angles, this might be a help too. I sure could've used one on my 2-4000 mile road trips!!
Re: 22R carbie throttle control [Re: Scerb] #865676 02/01/08 06:33 PM
stock87 Offline
Can't choke a diesel, so you have to manually raise the RPMs while it warms up on a cold day.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6234 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-06-22 06:04:34 UTC
