1996 T100 Parking Brake Light
#865916
02/01/08 09:33 PM
When ever I am accelerating up a hill or just at random times, usually in the same place as the day before, my parking brake light comes on. I know that this can be caused by not having enough brake fluid but I have checked the resivoar and it is pretty damn full. Does anyone know the cause of this problem?
Re: 1996 T100 Parking Brake Light
[Re: T100_4x4]
#865917
02/01/08 09:46 PM
Probably the sensor located at the top of the reservoir. I had mine topped as high as it would go and it would slowly fade in and out. I just unplugged it and check my fluids daily.
I guess you could replace yers as well...not sure how much they cost though.
Did you check the wiring on the parking brake switch? <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: T100_4x4]
#865918
02/01/08 11:32 PM
Pour in as much fluid as it will hold, without spilling when you put the top back on. That should fix it. Mine has to be to the rim.
[Re: J_Bird]
#865919
02/15/08 09:46 PM
Thanks for the advice, I did this yesterday and it fixed the problem. Strange how the resivor had plenty of fluid but if its just a hair low the light will come on.
[Re: T100_4x4]
#865920
02/16/08 07:39 AM
I picked up a '99 Runner last year; does the same thing. It's a lot more touchy about the brake fluid level than my old Toys.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6083 MB (Peak: 0.6725 MB) Data Comp: Off Server Time: 2026-05-29 19:51:40 UTCValid HTML 5 and Valid CSS
