Page 3 of 3 1 2 3
Re: rim to tire size [Re: jaybur] #865941 02/04/08 05:20 PM
Dave Scott Offline
in my situation I had to trim the front bumper and pound the seam flat to run 30x9.50x15. HOWEVER, I was running F150 rims which have less backspace (stick out more than a stock rim would).
well, there you go, with the stock rims, the only other thing that gets a little rubbed is the swaybar.
Re: rim to tire size [Re: Dave Scott] #865942 02/05/08 12:57 AM
dirtcrazy Offline
That's odd, cause I'm running 215s now and I rub on the rear shock mounts and the front sway bar during off roading. In fact, I had to grind down the shock mounts some cause it was chewing up the inner sidewalls. I do max the flex while wheeling, though. I don't know if that be why or not; just my 2 cents worth.
Got torque?
'02 Ford F-350 STD Cab V10 6sp 4x4
12MPG in town and 15-17 on the highway.
Re: rim to tire size [Re: dirtcrazy] #865943 02/05/08 02:38 PM
Dave Scott Offline
no, you're right, it rubs there too, it's just been so long since i've had the stock axles and even close to stock size tires and rims, i forgot... <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: rim to tire size [Re: Dave Scott] #865944 02/05/08 06:07 PM
sportagebandit Offline
http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_754162_-1
39 bucks a rim for 15 x 8 or 15 x 7. they look good and are cheap. i am runnin 15x 8 with 31 x 11.5 r 15 LTB super swampers.
dont rub in the rear at all. front rubs on inner fender only under extreme travel or getting air.
shoulda went with daves lift from the beginning. gonna have to swap out the eibachs spacer lift(a good lift but just not enough) to a rsg lift. already have the 1 3/8 body lift installed.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: rim to tire size [Re: sportagebandit] #865945 02/05/08 07:29 PM
jaybur Offline
I like those wheels, $160 for 4 rims brand new isn't too bad.
I paid $60 for 4 used chrome ones (no tires) and $40 for 4 used wagon wheel style ones (with tires which I was able to use while waiting for my mud tires and alignment, not too bad!
Sportage sold.........
1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6166 MB (Peak: 0.6979 MB) Data Comp: Off Server Time: 2026-06-07 06:57:28 UTC
