Page 1 of 4 1 2 3 4
Quick Question #866042 02/02/08 06:52 AM
TVS Offline OP
Was out with GaryInOz today for a quick blat and I mentioned to him that I am getting some spring spacers made up next week to go on top of my 2" longer springs. I am aiming to gain 4" lift in total over stock, so basically I want 2" more lift. He noted to me that the front spacer has to be less then 2" due to the radius increase of the way the suspension is designed. The rear obviously stick to 2" thickness being a solid axle. So basically what I want to know is what thickness spacers should I use to gain my 2" extra lift on the front?
Thanks
Damo
99 Kia Sportage, 50mm Lift, 30" Muddies, Manual Hubs, 2 1/4" Exhuast, Extractors, HiFlo Cat, K&N.
Re: Quick Question [Re: TVS] #866043 02/02/08 07:05 AM
DennisThompson Offline
I build the UPYOURKIA spacers so I have done rome research on this. with the 2 1/2" Eibach I use a 3/4" spacer to get to 4 inches. With your 2" springs a 3/4" spacer will get you about 3 3/4 inches. A 1" spacer will be 4 inches or a little higher but should work just fine. I have a bunch of 3/4" made so email me if interested.
Hope this helps, Dennis
Re: Quick Question [Re: DennisThompson] #866044 02/02/08 08:14 AM
TVS Offline OP
I need front and rear spacers. I would get some off you but being in Australia it's probably more pain then it's worth to get them over here. So basically you think I should build 1" thick in the front and 2" thick in the rear? Should be OK for my front CV's?
Thanks
Damo
Re: Quick Question [Re: TVS] #866045 02/03/08 05:00 AM
Yes, That would get you real close to the 4 inches you are after. I have shipped to Australia but I don't have 1" Just 3/4s and can make 1.5 to 2 inches.
Dennis
Re: Quick Question [Re: DennisThompson] #866046 02/06/08 12:47 AM
TVS Offline OP
Thanks Dennis,
also, do I need to have anything lengthened? Liek brakelines etc? Or is it basically lift it and go?
Also the rear auto locker is being fitted at the same time so I can let you know how that goes as well if you are interested.
Thanks
Damo
Re: Quick Question [Re: TVS] #866047 02/06/08 01:09 AM
jaybur Offline
auto locker? you mean the limited slip or an actual locker?
Sportage sold.........
1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Re: Quick Question [Re: jaybur] #866048 02/06/08 02:16 AM
TVS Offline OP
No No I have an actual rear auto locker sitting at home. I originally asked for a front locker, they supplied one but the carrier it came in was 10mm too wide for the front diff. I sent it back, they spent months trying to get i to work but decided they couldn't and said it will only fit the rear. So now I am having attempt number 2 at it. The company is called LMS Distributions (Korean Auto Parts). They are located in Australia, Sydney or Melbourne I am not sure. All the work is done in Korea and they distribute it here locally through this company.
Re: Quick Question [Re: TVS] #866049 02/06/08 03:03 AM
jaybur Offline
keep us updated!
Re: Quick Question [Re: TVS] #866050 02/06/08 03:28 AM
Nothing in the front needs to be lenghtend, in the rear just longer shocks. Just don't go to long or the springs fall out as the axle flexes. I'm jelous about the locker, they are hard to get in the US.
Dennis
Re: Quick Question [Re: DennisThompson] #866051 02/06/08 03:42 AM
Nukeiridium Offline
Dude... you have to give us more info about this rear locker!!
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6375 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-06-20 18:56:47 UTC
