Dim Headlight Solution, Thanks 4Crawler #866301 02/03/08 05:06 PM
Y
yota89 Offline OP
I really just wanted to say thanks to 4Crawler, for the awesome job he done with the headlight wiring harness he built for these older Toyotas that have the Dim Headlight Disease. Before I installed anything I checked voltages of the battery and the headlights with the Engine running. At the Battery I had a nice 14.7 Volts, with the Low beams on I was geting a reading of 12.5 volts, and with high beams on it dropped to 12.23 volts. AFter installing the Harness I was able to get 14.5 volts at the headlights with both low and high beams on. I went ahead and took his advise on some after market light housings that let you replace the bulb instead of the whole headlight assembly. I had a busted lense in one light, so I was able to justify they whole upgrade. I ended up spending $45.00 including shipping for the harness, and Each Light Housing (200mm Hella Vision Plus) was $36.00, and then I bought a pair of Hella High Performance Xenon Blue Bulbs for $27.00 The bulbs arnt Xenon bulbs, they just have a blue tinting on them that produces a clean white light without that annoying Blue light that alot of newer cars have. I must say that, was the best $150.00 I have spent in a long time. I was so hyped about them last night when I got done and was able to see how great it all looked I drove 15 miles to my Dads house to show him since he has a 90 toyota 4x4 with the same issues. Needless to say he was very impressed and has this upgrade on his soon to do list. Heres a few pics of the Harness and lights installed, I will try to get some night time pics tonight. Thanks again 4crawler <img src="/forums/images/graemlins/smile.gif" alt="" />
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: Dim Headlight Solution, Thanks 4Crawler [Re: yota89] #866302 02/04/08 01:37 AM
ldivinag Offline
you should think about replacing your batt terminals too...
they look WAYYYYY too dirty/old/corroded.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Dim Headlight Solution, Thanks 4Crawler [Re: ldivinag] #866303 02/04/08 01:56 AM
4Crawler Offline
Install looks good, you might want to set the relays so they sit upright to keep water out better. Sounds like you saw a decent increase in light output with a 2+ volt increase.
Re: Dim Headlight Solution, Thanks 4Crawler [Re: ldivinag] #866304 02/04/08 02:05 AM
Y
yota89 Offline OP
LOL there not dirty there Brass connectors, they tarnish a little bit but have a very clean contact surface.
I definitly got alot better output, my lights now look better than my 07 Tacoma.
Thanks
89 yota pickup
22RE 261C cam
Re: Dim Headlight Solution, Thanks 4Crawler [Re: yota89] #866305 02/05/08 09:48 AM
kewlynx Offline
Great post; I need to do this upgrade on Ol' Blue myself. Thanks for putting this up! <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Dim Headlight Solution, Thanks 4Crawler [Re: yota89] #866306 02/05/08 05:45 PM
Jeepeater Offline
Roger's harness is a fantastic upgrade and easy to install. I did it two years ago and love it! I highly recommend doing this mod as well. Plus, Roger is a pleasure to deal with and ships quickly. What more can a customer ask for?
I put in some headlights from roundeye.com and they helped a bit too. With the H4 bulbs, I can replace them with anything I want any time I want easily and inexpensively.
Re: Dim Headlight Solution, Thanks 4Crawler [Re: Jeepeater] #866307 02/06/08 04:16 PM
BRreddog Offline
I just did the harness mod this week. I already had the Hellas so I didn't notice as much of an improvement, but there was a difference. Going to upgrade bulbs soon.
Definetly recommended !
'86 22R Bored .080", Stroked 5.5mm, LC header, Downey 2.25" SS exhaust, 33" SST Coopers, 4W disk brakes, T-Case brake, PRP Seats
Re: Dim Headlight Solution, Thanks 4Crawler [Re: BRreddog] #866308 02/06/08 05:41 PM
4Crawler Offline
How much improvement you'll see with the harness installation depends on what sort of voltage drop you have in your existing wiring. Easy enough to test with a volt meter, probing the back of the headlight connector itself (with the lights on):
More info. including a chart of light output vs. voltage:
http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#VoltageTest
Re: Dim Headlight Solution, Thanks 4Crawler [Re: BRreddog] #866309 02/07/08 04:33 AM
Y
yota89 Offline OP
These are the lights got, (HL83200
H4/9003/HB2 Bulb, 12V, 60/55W, Hella High Performance Xenon Blue, per Pair 27.66) They produce a cleaner whiter light than the regular halogens.
lights
89 yota pickup
22RE 261C cam
Re: Dim Headlight Solution, Thanks 4Crawler [Re: yota89] #866310 02/07/08 04:49 AM
G
Greg_Canada Offline
My fav bulbs are the standard 80/100w hella's. they throw out tonnes of light. i dont like the "white" light, i feel it doesnt light up as much, i had some and changed them out for higher wattage stockers.
89 4Runner
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6440 MB (Peak: 0.7701 MB) Data Comp: Off Server Time: 2026-11-04 13:36:52 UTC
