Page 2 of 3 1 2 3
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: Vanishing_Point] #866390 02/05/08 06:39 AM
DRTDEVL Offline
Replaced mine when I rebuilt the engine and never had a problem.
I didn't just rebuild. I BUILT it.
0.040 bore
SS psitons
SS OS valves
270.430 cam
hv oil pump
bored TB
gasket matched intake
disabled EGR (not for performance, but for being cheap... It smacked the firewall when reinstalling the engine cracking the pipe. I just blocked it off instead of paying $$$$$ for a new one)
The other peice to my equation is environment... I couldn't keep the engine cool enough when I lived in Florida. ***poof*** Now I can't keep it cool enough when pulling grades in the Alps. Or when rolling 100+ on the Autobahn. Numerous excessive heat cycles are causing my failures. None happened during an overheat, but I attribute the eventual failure to excessive heat.
I haven't ordered my new gasket yet... I can't afford everything else I am going to do at the same time. I am replacing the radiator with a HD V6 one, and adding a digital temp guage, so I never have to go through this again.
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: sdsnowman] #866391 02/05/08 07:13 AM
kewlynx Offline
I've been doing a little work in the back, and came across this in a roundabout way; good tech read!
Engine Builder Magazine
**ubi apis- ibi salus**
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: DRTDEVL] #866392 02/05/08 04:34 PM
stock87 Offline
0.040 bore
SS psitons
SS OS valves
270.430 cam
hv oil pump
bored TB
You know, you may want to re-enable the EGR system. Does a nice job of keeping combustion temps down. More than you might think, actually.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: BROWNBAGG] #866393 02/05/08 11:07 PM
dcg9381 Offline
I'm surprised no one has mentioned the quality of HGs that are recommended or increasing the clamping force on the head via using ARP hardware.
22REturbo.net
1988 4Runner
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: dcg9381] #866394 02/06/08 12:41 AM
4Crawler Offline
I've had the ARP stud kit on my 22RE for 8 years now with an OEM head gasket and no problems at all. The other big help is to keep the engine cool, even getting a few ticks from the red zone on the factory gauge can cause the head to warp and the HG to fail. Happened to mine a few times before upgrading to a 3-row radiator and running a dual valve thermostat.
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: 4Crawler] #866395 02/06/08 04:10 PM
BRreddog Offline
I'm running ARP studs, a FelPro gasket, 2 core aluminum radiator and a AutoMeter mechanical water temp guage. Going on 40k with absolutely no problems. My original head gasket went about 80k but the truck had been overheated several times when I had radiator/water pump problems.
'86 22R Bored .080", Stroked 5.5mm, LC header, Downey 2.25" SS exhaust, 33" SST Coopers, 4W disk brakes, T-Case brake, PRP Seats
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: 4Crawler] #866396 02/11/08 12:30 AM
G
GOI87 Offline
Where is a good place to get the ARP hardware? Apparently I need to redo my HG, and was trying to avoid doing it again.
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: GOI87] #866397 02/11/08 01:18 AM
4Crawler Offline
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: 4Crawler] #866398 02/11/08 01:33 AM
G
GOI87 Offline
well, I came up with 2 arp numbers
ARP-203-4201 (this looks like it replaces all the bolts on the head with studs) costs around $130 at summit
ARP-203-5406 (this looks like it JUST for the Head bolt replacement studs) costs around $80. I'm guessing this is the one I need for doing a HG job.
Suggestions/confirmations?
Re: how to: keep a 22re HG from failing???? Is it possible??? [Re: stock87] #866399 02/11/08 02:01 AM
IceBlueT Offline
0.040 bore
SS psitons
SS OS valves
270.430 cam
hv oil pump
bored TB
X2
EGR is actually designed to keep combustion temperatures down, not just to keep NOx emissions, but to also keep the engine from being damaged by excessive heat from high combustion temperatures.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6539 MB (Peak: 0.7769 MB) Data Comp: Off Server Time: 2026-06-07 09:44:44 UTC
