Rating: 5
Page 4 of 51 1 2 3 4 5 6 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Chris_Eichman] #866538 04/12/08 04:46 PM
Hydra747 Offline
Body Lifts here: <img src="/forums/images/graemlins/kewl.gif" alt="" />
web page
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866539 04/15/08 03:56 AM
mudz Offline
any body know how i should go about lifting a 2WD sporty, yes i said 2wd...
i just want to lift it about 2 inches, could i use spring spacers or is that only for 4wd.
let me know i need some serious advice
and please dont tell me to get a 4wd sporty, if that was possible at this moment in time than i would
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: mudz] #866540 04/15/08 04:55 AM
Chris_Eichman Offline
The spring spacers are all the time. Send an email to upyourkia@yahoo.com He can help you out.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Chris_Eichman] #866541 04/30/08 08:16 AM
BAZINGA Offline
Would someone like to hazard a guess as to how a Kia Sportage with a 4" suspension lift with tyres 235 75 15 would look.
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866542 04/30/08 02:26 PM
Everet Offline
Not as good as it would with 31 10.50's!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Everet <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866543 04/30/08 03:44 PM
BAZINGA Offline
the 31x10.5 would look great, but i'm on a budget. as long as the 235 75 15's dont look stupid with the 4" lift
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866544 04/30/08 05:34 PM
Everet Offline
I know with 205's and my lift it looks pretty lame. Check <a href="www.craigslist.com" target="_blank">CRAIGSLIST</a> off and on and you may find a good deal. If you want new, Schawb has some pretty good deals. Look at 30 9.50's as an option.
Everet <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866545 05/06/08 04:31 PM
wyodriver4 Offline
i like the look of the 235/75r15 i run. dont think they look bad at all. they actually measure at 29.25 dia. and 8.9 wide, so its not a huge amount smaller than 30x9.5. may not look as mean a 31x10.5 but looks a thousand times better than stock.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866546 05/12/08 05:20 PM
BAZINGA Offline
what has happened to dave's rocksport gear page?
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866547 05/12/08 05:28 PM
BAZINGA Offline
TIRES:
235 75 15 is also a good choice if you are running a 2" lift. its a very common tire size, so there are many options and styles available. Fits on standard rims, no lift required, although some minor trimming of the underside of the front bumper will be needed (~0.5" x 6" strip)..."
where precisely do you need to trim and how major is it? will the trimming be noticed? I'm concered that I might stuff it up ('cause I dont know what to do)
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6520 MB (Peak: 0.7755 MB) Data Comp: Off Server Time: 2026-05-29 19:57:00 UTC
