Rating: 5
Page 10 of 51 1 2 … 8 9 10 11 12 … 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: logansportage] #866598 02/07/09 10:40 PM
3
357transam Offline
Well, I just put 104s on the rear of my '98, and tried the Ironman "extended" shocks, but they werent any longer than the stock ones. I would definately say use the rav 4 shocks instead, as these don't allow for any real flex.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866599 02/10/09 05:00 PM
londart Offline
just curious, how does a 2" spacer give you 3.25" lift...is this a hard upgrade,ive never done a lift but otherwise pretty mechanically inclined....any other mod recomendations...have a 95 dohc 4dr manual w/warn manual locks, elec fan w/bypass and came w/ some sort of turbo exhaust but still has the cat, 30-9.5 coopers w/stock rims for now...how much for the front spacers and what year tj for the rear upgrade...i work for a federated parts store so i get pretty good prices on new parts or know quite a few people that mess w/ jeeps can probably get some used stuff pretty decent priced
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: londart] #866600 02/10/09 06:15 PM
Everet Offline
Doesn't matter the year, what matters is the tag on the springs. 104AA's will give you 3" of lift. 106AA's will give you 4" of lift. If they don't have tags, then you will need to remove them and measure them for height (12") and spring rate (250 lbs/in for the 106AA's don't remember what the 104AA's are).
As far as spacers for the front go, I'll pm you with pricing.
I don't know where you came up with the number 2" = 3.5" of lift. That isn't the formula, however, think of a teeter totter. The closer you are to the fulcrum, the shorter the travel.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866601 02/11/09 06:22 AM
londart Offline
came up with the 2"=3.25 off of this site....jaybur...1st listing at top..2" spacer (provides about 3-1/4" lift)
Lonnie
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866602 02/12/09 06:46 AM
londart Offline
found some used rear coils online...no tags...does anybody know if they should be out of a 2.5l, 4.0l, or a rubicon for a 3" lift on the rear? <img src="/forums/images/graemlins/confused.gif" alt="" />
Lonnie
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: londart] #866603 02/24/09 09:30 AM
Delarey Offline
I am interested in a BODY lift on my car, in other words, leave the suspension alone!
Has anybody done it and how does one go about it?
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Delarey] #866604 02/24/09 07:01 PM
Everet Offline
Check out this link: BODY LIFT
This has a pretty good discussion on how they work.
If you need some I will work up a quote.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866605 03/21/09 06:08 AM
Hello To All!
Just joined after reading this whole post.
I am doing the 3" lift I have decided.
Only thing is I am not sure what to get for the front. The rear was explained in a few different replies, and only a couple about spacers for the front?...Is this correct?
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. #866606 03/21/09 01:19 PM
DennisThompson Offline
Everet Makes the front spacers, go to (upyourkia.com). Dave Scott does an all spring lift. The Pro's and con's of both.
Spacers pro's, inexpensive, strong, easy to install and quick transaction. Cons, limits front wheel travel. I have ran the spacers for over 100,000 miles with no problems at all.
Spring Pro's, better wheel travel, firmer ride. Con's, Price is much higher, a little more work to install and takes more tome to get them.
Hope this helps, Dennis
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: DennisThompson] #866607 03/21/09 07:20 PM
ChrisB Offline
Will xj springs off a 96 grand cherokee fit?My brother just lifted his jeep and there laying around
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
PHP: 7.4.33 Page Time: 0.805s Queries: 16 (0.654s) Memory: 0.6538 MB (Peak: 0.7776 MB) Data Comp: Off Server Time: 2026-10-21 16:20:55 UTC
