Rating: 5
Page 40 of 51 1 2 … 38 39 40 41 42 … 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: RyanR] #866898 01/16/14 03:06 PM
Tommychu Offline
Is there another way to get ahold of Everet? I emailed last week (the @upyourkia.com address) and haven't heard back yet.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Tommychu] #866899 01/17/14 02:04 AM
RyanR Offline
I got my front lift from Everet today, and it looks good! (Thank you Everet!!) Already started the install, and I'll keep you posted.
Did u pm Everet? You may give him some time, he's been sick.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: RyanR] #866900 01/18/14 05:49 AM
RyanR Offline
Done with the front. It was a little tricky getting the spring spacers in, but it's done. I'll post more when I get the rear springs.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: RyanR] #866901 01/21/14 05:24 AM
RyanR Offline
We'll all done with the lift. Overall it wasn't bad. Allandall it took about 8 hours. Rear was superfast. I used KYB rear shocks, 99' rav4. Rear springs I ordered from my local spring shop, for 04' Rubacon. Wheels are Vision Warrior 357 16" x 8", with 265 70 16 4 ply ( to keep weight down) I made steel brackets for the factory front bumper to push the corners out so I didn't have to butcher the plastic. I also trimmed the plastic inner fenders front, and back of the front tires. I'm going to try to post before, and after pics (But I suck at that stuff).
Still upset I can't just order diff locks at a reasonably good price.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: RyanR] #866902 01/21/14 06:51 AM
4
4runnernomore Offline
Why not? The difflocks ain't that expensive from Korea especially shipped to the US.
You should try Australian prices for difflocks, you guys get them for a steal. <img src="/forums/images/graemlins/scared.gif" alt="" />
I use photo bucket for my pictures, Found that the easiest way to post on sites.
Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: RyanR] #866903 01/21/14 03:09 PM
Davey Offline
Diff locker is well worth whatever it costs <img src="/forums/images/graemlins/wink.gif" alt="" />
Front lift spacers are a P.I.T.A. to do.. especially with stiffer coils. How's your cv clearance from the strut forks?
I got KYB RAV4 shocks for the rear too - but have found them way under damped, still usable at least. Mine is the long body version, could be why
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866904 01/21/14 04:35 PM
RyanR Offline
The cv clearance is tight. Actually the boots rub.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866905 01/22/14 02:43 AM
4
Mine is under damped as well Davey all round, KYB struts in the front and OME RAV 4 rears and mine is the little bumb. I think it more related to the heavier spring rates.
myself and Runt 313 a still looking into trying to source a shock replacement to provide better dampening as well as fixing the front AARm issue with the 4 inch lift.
No issues with my struts as I was able to source the extended front struts which fixes the rubbing issue.
Cheers, Chris
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 4runnernomore] #866906 01/22/14 06:00 AM
Peabody Offline
Here's what I'm running in the rear. Made all the difference after bolting a few hundred pounds of steel and 2 batteries to the rear of my Sporty.
The shocks are Pro Comp ES9000 series - #924515 . They are spec'd to fit the following vehicles (front shocks, I think):
1984-2010 Ford F-250, 1984-2010 Ford F-350, 1984-2010 Jeep Cherokee, 1984-2010 Jeep Grand Cherokee, 1984-2010 Jeep Wrangler
They're working for me. If you need a little more oomph in your shocks, give one of those sets a try...
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Peabody] #866907 01/22/14 06:06 AM
4
Thanks Peabody,
will look into it.
been a twin tube shock do you have clearance issues? <img src="/forums/images/graemlins/scared.gif" alt="" />
I would like to try and find a fix for the front at the same time so it is balanced if I can.
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.015s) Memory: 0.6531 MB (Peak: 0.7780 MB) Data Comp: Off Server Time: 2026-10-24 02:37:02 UTC
