Bolt Size #867131 02/05/08 04:48 AM
L
Littlewhitepup Offline OP
I have a 2.3 2wd pickup. my rear end is leaking where the drive shaft enters it. Does anyone know the size of the nut that removes the part that is attached. I can det the drive shaft off with no problems but then there is the hugh nut.
Re: Bolt Size [Re: Littlewhitepup] #867132 02/05/08 05:39 AM
strawmyers Offline
Isuzu Moderator
Assuming the 10-bolt rear is the same as its front-end counterpart, you don't want to go just haphazardly messing with that. The pinion preload is set with a crush sleeve and you'll need a new one and the ability to correctly install it if you take down that part of the axle. IIRC
Sean Strawmyer
Re: Bolt Size [Re: strawmyers] #867133 02/07/08 05:11 AM
L
Oh, I was told by the isuzu dealer ship that is isn't that hard. They said I could use the same crush washer I just need to only tighten it to 70ft lbs. How should I get the leak fixed then? Do I need to have tehm do it?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5946 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-05-29 16:42:06 UTC
