Bolt Size
#867131
02/05/08 04:48 AM
I have a 2.3 2wd pickup. my rear end is leaking where the drive shaft enters it. Does anyone know the size of the nut that removes the part that is attached. I can det the drive shaft off with no problems but then there is the hugh nut.
Re: Bolt Size
[Re: Littlewhitepup]
#867132
02/05/08 05:39 AM
Isuzu Moderator
Assuming the 10-bolt rear is the same as its front-end counterpart, you don't want to go just haphazardly messing with that. The pinion preload is set with a crush sleeve and you'll need a new one and the ability to correctly install it if you take down that part of the axle. IIRC
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
Re: Bolt Size
[Re: strawmyers]
#867133
02/07/08 05:11 AM
Oh, I was told by the isuzu dealer ship that is isn't that hard. They said I could use the same crush washer I just need to only tighten it to 70ft lbs. How should I get the leak fixed then? Do I need to have tehm do it?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-05-29 22:40:49 UTCValid HTML 5 and Valid CSS
