positive vacuum\negativ4e vacuum #867456 02/06/08 01:06 PM
DRCYCLOPS Offline OP
which one sucks which blows pardon the pun but im confused re oil in breath <img src="/forums/images/graemlins/confused.gif" alt="" />er big jim help me please
Re: positive vacuum\negativ4e vacuum [Re: DRCYCLOPS] #867457 02/06/08 05:40 PM
BigJim Offline
Pardon but I don't understand the question... ALL vac is negative pressure. If refering to the pcv it's job is to take the negative pressure in the carb area and allow the pressure in the valve cover to leak into the intake.
The OTHER hose on the valve cover is there to supply fresh air to the valve cover in newer engines. (ones that don't yet have blowby) If an engine has too much blowby for the pcv to handle The second hose can be attached to a vac source and between the TWO hoses the blowby should be taken care of.
Re: positive vacuum\negativ4e vacuum [Re: BigJim] #867458 02/07/08 01:53 AM
Thanks I was refering to you saying positive vacuum so your saying try adding another pcv valve and teeing in Ill try that thanks
Re: positive vacuum\negativ4e vacuum [Re: DRCYCLOPS] #867459 02/07/08 04:51 AM
BigJim Offline
I havn't bothered with a pcv...I just connect it to vac and go on about my business.. The pcv is only there to prevent a possible fire...Which wouldn't have occured in any of the engines built to date..
Re: positive vacuum\negativ4e vacuum [Re: BigJim] #867460 02/08/08 12:35 PM
wouldnt that dump oil right into the combustion chamber?
Re: positive vacuum\negativ4e vacuum [Re: DRCYCLOPS] #867461 02/08/08 05:02 PM
BigJim Offline
SO? It will take the internal pressure out of your engine.
That pressure will cause seal leaks if it hasn't already. And that small amount of oil will go unnoticed in the engine..
Re: positive vacuum\negativ4e vacuum [Re: DRCYCLOPS] #867462 02/08/08 09:31 PM
Bigbird79 Offline
Think about it this way. Atmospheric pressure at sea level is 14.7 psia, so anything that has a higher pressure than 14.7 psia will be a ôpositiveö pressure, or will ôblowö. Anything less than 14.7 psia will be a ônegativeö pressure, or a vacuum, and will ôsuckö. The other thing to think about too, is when you fill up your tires, you are looking at a gage pressure and not an absolute pressure. Hopefully this helps.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: positive vacuum\negativ4e vacuum [Re: Bigbird79] #867463 02/09/08 10:32 PM
Gonna try that tomorrow,I ahvent blown any seals the oil is just all over the garage floor.as it comes out the breather the motor is brand new (10k)
Re: positive vacuum\negativ4e vacuum [Re: DRCYCLOPS] #867464 02/23/08 09:53 PM
fresnodb Offline
Something sounds wrong there, a good motor shouldn't have ANY oil in the air filter box.
Back in the game!
'94 YJ 2.5 all stock.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6271 MB (Peak: 0.7140 MB) Data Comp: Off Server Time: 2026-11-17 11:29:08 UTC
