YJ Windshield Frame on a CJ #867919 02/08/08 07:50 AM
burtv Offline OP
Has anybody swapped a YJ windshield frame onto a 78-86 CJ7 body tub? Any problems or ??
Re: YJ Windshield Frame on a CJ [Re: burtv] #867920 02/08/08 03:22 PM
Brown81CJ5 Offline
The dimensions are the same....I also assume that the mounting holes are the same.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: YJ Windshield Frame on a CJ [Re: Brown81CJ5] #867921 02/08/08 06:29 PM
burtv Offline OP
I have heard the defrosting vents and the wiper motor placement was different but have no way to confirm. I have not found anyone who has done this conversion. Can anyone confirm the venting or motor placement?
78 CJ7, 83 wide track axles/Dana 30 Front W/ OX Locker, Model 20 rear w/ one piece shafts(welded tubes)/Detroit Locker, 4.10 gears. 4.5" spring lift with 3/4" shackle lift. 35x12.50 BFG MT, 4.2L, Weber Carb, K&N, T18,Scout Dana 300,Warn 9.5ti
Re: YJ Windshield Frame on a CJ [Re: burtv] #867922 02/08/08 11:22 PM
F
Fred Blackstone Offline
I suspect the YJ and CJ-7 windshield frames are different; just look at replacement W-S- frames ads, frames are listed with different part numbers. Wish I could find my frame spec guide ... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: YJ Windshield Frame on a CJ [Re: Fred Blackstone] #867923 02/09/08 06:10 AM
O
oldgreen Offline
I swapped a YJ frame to my CJ the only difference I noticed was the CJ frame is hollow all around, the defrost has to heat up the entire windshield frame which has the effect of cooling the air in it, not a big deal in California but here the winters can go as low as 45 below with the wind chill. The YJ frame had a baffle welded or formed into it a little ways up on each side which meant the defroster gets a shorter path to the windshield and doesn't have to warm up the whole windshield channel. Other than that the one I got was the same dimensions etc as the CJ.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6074 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-06-07 09:12:46 UTC
