Speedo recalibration - any benefits? #867978 02/08/08 11:13 PM
1
1neuron Offline OP
The following was posted in a different thread, and I didn't want to jack it so I thought I'd ask separately: are there any actual mechanical benefits to recalibrating your speedometer after increasing tire size/changing gearing? I found this link where they claim benefits to mileage, reduced wear, better shift points, etc. Do you guys think these claims are legit?
Something else I forgot to add. If and when you change to a bigger tire, your speedometer and odometer will be off.
I used a TruSpeed Speedometer Recalibrator.
It corrected my speedo when I went from 31" to 33". If I decide to go up to 35" tires I can adjust again to correct the speedometer without extra expense.
99 XJ, 4.5" RE lift, SYE+driveshaft, 31" BFG ATs, Warn rear bumper+tire carrier, JCR front bumper and sliders
Re: Speedo recalibration - any benefits? [Re: 1neuron] #867979 02/09/08 01:47 AM
BigJim Offline
Yes there can be benefits.. My cealer will change the computer for me for $50. I see no reason to spend more than that..
Re: Speedo recalibration - any benefits? [Re: BigJim] #867980 02/12/08 02:27 AM
DBL_DTY97TJ Offline
You can get the right speedo gear for half that. The only benefit would be not racking up extra milage if you've regeared lower than stock for ins. or resale purposes (after figuring in your bigger tire size), or you can't figure your speed in your head on the road. I haven't bothered. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5946 MB (Peak: 0.6483 MB) Data Comp: Off Server Time: 2026-10-24 07:18:02 UTC
