Page 3 of 3 1 2 3
Re: Tips for making IFS stronger [Re: Snowtoy] #868070 02/14/08 07:30 PM
Baldy Offline
This takes care of but one weak link in the IFS. What do you do when you start snapping axle shafts.
Re: Tips for making IFS stronger [Re: Baldy] #868071 02/14/08 09:13 PM
DRTDEVL Offline
More brain, less skinny pedal. <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Tips for making IFS stronger [Re: DRTDEVL] #868072 02/14/08 11:13 PM
P
PETE_YK Offline OP
Lower gears!
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Tips for making IFS stronger [Re: PETE_YK] #868073 02/15/08 12:06 AM
Snowtoy Offline
X2
X2
Being able to crawl over the rocks and keeping your tires straight is the best way to prevent breakage regardless of what you are wheeling.
When do you usually see breakage of either cv's or birfs on the trail?, with speed and with wheels turned. More times than not the driver is trying to find tracton with either the wheels turned sharp, or turning the wheels back and forth, or with the wheels turned and up against a rock. This type of breakage can usually always be avoided by stopping and stacking a rock, or backing up and taking another line. I know it is less fun to have to engineer the trail a little to get the rig over an obstacle, while powering over it gets you applause/yells from bystanders, but to me, spending hours on the trail side fixing your junk just doesn't seem to be worth the applause.
Re: Tips for making IFS stronger [Re: Snowtoy] #868074 02/18/08 07:24 AM
P
PETE_YK Offline OP
While on the subject, and just out of curiousity...does anyone out there make heavy duty ball-joints, tie-rod ends etc.?
Re: Tips for making IFS stronger [Re: PETE_YK] #868075 02/20/08 12:30 AM
Snowtoy Offline
OEM or Moog are about as strong as you can get, I put Beck/earnly(Made in Japan) on my '91.
As far as I could find out(after breaking one) the tie rod ends on the 1/2tons are the same size as those used on the 1ton 2wd, the T100's and the 1st gen Tundra. I think the ones used on the Cruisers(not FJC's)) are bigger, but I am not positive. The easiest/cheapest thing to do is go to the wrecking yard and get some spares, they don't take up much room at all.
Re: Tips for making IFS stronger [Re: Snowtoy] #868076 02/20/08 12:27 PM
JonJ634 Offline
Good subject!
I have had a brainless idea for awhile and wondered if it would be feasible to completely remove the torsion bars and use coil-overs instead?
This may not be possible at all, just wondered since
I think the newer tacos don't have torsion bars any longer?
Just my thoughts.
Jon
1994 Toy
Re: Tips for making IFS stronger [Re: JonJ634] #868077 02/20/08 07:05 PM
grandeyota Offline
This may not be possible at all, just wondered since I think the newer tacos don't have torsion bars any longer?
Sure is possible, and already done <img src="/forums/images/graemlins/smile.gif" alt="" />
Total Chaos
Fur clog in the sausage grinder
Re: Tips for making IFS stronger [Re: grandeyota] #868078 02/20/08 07:29 PM
RatLabGuy Offline
Total Chaos
But if you wanted coilovers, why do you need to necessarily replacet he A-arms, joints etc? Why not just use the stock suspension, but w/ the coils in coil-overs replacing the function of the torsion bars?
In the end, while this might gain you some flexiness, the weak point/problem is still the CV axles/joints. By the physics of how one works, a CV simply can't deal with large angles.
Question Reality.
Re: Tips for making IFS stronger [Re: RatLabGuy] #868079 02/21/08 01:23 AM
Snowtoy Offline
I think there isn't enough room with the oem A-arms to allow a coil over to be bolted in. IIRC, the Chaos kit has wider A-arms.
If you are breaking Cv's do to steep operating angles you can replace them w/Porsche 911 CV/s for about $1500. Of course once you add it all up you are at the same costs of a built SAS, so it would depend on what you are doing w/your truck.
Steep angle are bad regardless of what you have, IFS or SA, driving style and keeping your ego in check will prevent a lot of breakage.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6390 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-07-15 00:08:50 UTC
