Found a different yota #868401 02/11/08 02:18 PM
grandeyota Offline OP
At the Okeechobee mudfest this weekend I spotted this thing:
The guys said he can drive it from either side, just has to lock the steering column!
Fur clog in the sausage grinder
Re: Found a different yota [Re: grandeyota] #868402 02/11/08 03:02 PM
toyrunner Offline
Was it coming, or, going? <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Kinda cool. Reminds me of an old VW bus that had two fronts on it.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Found a different yota [Re: toyrunner] #868403 02/11/08 04:02 PM
RatLabGuy Offline
Pretty slick.
But the magic question is - can it be run in 4WD? That would be the shizzit.
I assume it's just two front-wheel-drive setups. Or, I guess you could lock the "rear" in reverse, lol.
Question Reality.
Re: Found a different yota [Re: RatLabGuy] #868404 02/11/08 04:15 PM
I've been kicking myself for not looking under it when I was there. Now I'm going to spend eternity wondering just what makes it go.
Re: Found a different yota [Re: grandeyota] #868405 02/11/08 05:51 PM
RatLabGuy Offline
I'd think your better bet would be to dig around and try to find the owner. I mean, tehre can't be too many of these out there, right?
I'd think that between all the Yota boards, somebody would know who made this thing.
Then we overburden the guy with 4 million questions!
In all honesty, just "making it go" shouldn't be all that complicated. People do thsi w/ FWD cars all the time... you only need the front half to drive at all, just cut it off and attach 2 together.
My bet is, they just removed the rear driveshaft, and each half runs on the fronts w/ hubs locked. Put the "rear" t/c in neutral (or unock hubs), and off you go.
Question Reality.
Re: Found a different yota [Re: RatLabGuy] #868406 02/11/08 10:09 PM
V
v8yota Offline
i might be wrong but i think that is my old truck(s),,,i built back in 98,,and a guy in GA bought it in 01,,,if it is then it can be driven from both ends ,,,forword and reverse,,,it only has the front driveshaft on it there is no rear driveshaft,,it is run off of the t-case,,,all steering parts in the back cab are welded fast
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6089 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-07-15 08:01:12 UTC
