Ok, well after changing out Drivers seat I would like to do some other maintenance upgrading to vehicle Acura "98" SLX-(by Isuzu Trooper factory). The power mirror switch has not worked from the time vehicle was purchased (bought from former owner). Is there a fuse for power mirror switch or is the switch just bad. When cleaning vehicle it look like someone spilled soda or coffee everywhere. This is why I had uninstall both seats getting to take apart console for cleaning (vacuum-simple green). If it's a fuse this would be great, if not anybody have a working switch they like to part with? Also, the sunroof button console area-the driver overhead light is missing a button, tried to replace with a spare one with no correction. It has a little hole on the back of the button with a spring inside and a red little dot to push the light switch on/off. I think the whole console has to be replaced, not sure. Because when I took off the the replacement part button, where the redbutton touches the switch theres two metal pieces, on the vehicle there is only one-this could be the reason because light bulb is good. <img src="/forums/images/graemlins/patriot.gif" alt="" />
