Lockers #868445 02/11/08 07:22 PM
thunder72 Offline OP
What is the best locker for a dana 35. And will it be ok to lock it or is something bad going to happen. I am thinking aussie lockers. But any suggestion are welcome
Re: Lockers [Re: thunder72] #868446 02/11/08 07:51 PM
BigJim Offline
Best locker if mud bogging would be a SPOOL. If on an icy hiway..NO LOCKER would be best..
So what needs to be splained here is what are we going to do with this vehicle and when would we need a locker?
Re: Lockers [Re: BigJim] #868447 02/11/08 08:37 PM
I us it for a lot of mud trail riding and a little rock and hill stuff but it still needs to be my daily driver even though i only drive like five miles a day.I plan on a RE 2 inch budget lift with the locker. I just put 31 ,10.5, 15s
Coopper discovery STT's they give sweet grip. And am ready to start the mod process just have a budget.
Re: Lockers [Re: thunder72] #868448 02/11/08 10:57 PM
F
Fred Blackstone Offline
For 31x10.50s, the Aussie locker would be a good choice. Your offroad driving skill will be the determining factor almost all the time as to whether or not you snap an axle. Just carry an extra set of axleshafts for the D35 when your four wheeling and a few tools and gear oil (and something to catch the old gear oil). Normally its the axleshaft that breaks: just hope the differential doesn't get messed up when it does snap. It's an easy job to replace an axleshaft. The important thing is to get out all of the broken axleshaft pieces.
Re: Lockers [Re: thunder72] #868449 02/12/08 02:15 AM
DBL_DTY97TJ Offline
See my reply to "rear ends". <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Lockers [Re: Fred Blackstone] #868450 02/16/08 11:30 PM
E
el_d_m Offline
I am so with you BJ!!!! those silly d35's hehehehehe. Just tell the poor guy to trade up to a dana 44 or a chrysler 8.25 & lock those. hell even go junking & find an old bronco & use the 9inch out of it. i used the 9 inch & locked both axles on my xj! couldnt be happier. <img src="/forums/images/graemlins/cheers.gif" alt="" />
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6074 MB (Peak: 0.6771 MB) Data Comp: Off Server Time: 2026-11-02 08:47:21 UTC
