88 Wrangler 4.2 upgrades #868460 02/11/08 07:50 PM
kerby2 Offline OP
Just got my 1st jeep, needs some work. Here is my thoughts of upgrades: Change head to 4.0, add motorcraft 2100 carb, add header, install HEI dist. Let me say this, converting to MPI: to expensive, out of budget. Correct me if I am wrong, adding 4.0 head gives me more highend torque, motorcraft 2100 carb seems to have the best reviews, These all seem to be simple enough changes.
Kerby2
Re: 88 Wrangler 4.2 upgrades [Re: kerby2] #868461 02/11/08 08:00 PM
BigJim Offline
Well Keith you are gonna spend a bunch of money on that engine anyway..For just a bit more go first class and put the complete 4.0 in there..
Look around and see what a donor vehicle would cost that already has everything you'd need in it.
Although the components you mention can be made to work..they do not FIT each other perfectly. There is a lot more to be gained by putting everything that does fit in there at the same time.
Re: 88 Wrangler 4.2 upgrades [Re: BigJim] #868462 02/11/08 11:15 PM
kerby2 Offline OP
I considered a 4.0 swap then ran across the articles about just using the 4.0 head with the reasoning of keeping the 4.2 block getting the low end torque and adding the 4.0 head to increase the top end. thats the theory anyway. need input from someone who has done this modifcation for results. thanks big jim for the suggestion to put this on the forum. lets get some feedback...
kerby2
Re: 88 Wrangler 4.2 upgrades [Re: kerby2] #868463 02/11/08 11:58 PM
Brown81CJ5 Offline
Cuervo posted some links to info and write ups on this subject.
Third post from top.
links to 4.0L head swap
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6002 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-06-22 06:13:00 UTC
