Re: Changing timing chain and gears, a little confused [Re: KiwiCowboy] #868512 02/17/08 06:04 AM
damitboy Offline OP
Done! Well, sort of. It took five hours last night and about twelve hours today an it is all buttoned up. I just have to add coolant in the morning and I'll fire it up. Man I'm keeping my fingers crossed. That was a hard job. I hope it is sealed well. I made sure to clean all gasket surfaces really well so we'll see. I also learned alot about my Jeep and if all goes well this will be a big confidence builder for the next job. Thanks for all the input.
94 XJ 2 Door/2.5/5 SPD/4 WD
Re: Changing timing chain and gears, a little confused [Re: KiwiCowboy] #868513 02/17/08 06:04 AM
damitboy Offline OP
Re: Changing timing chain and gears, a little confused [Re: damitboy] #868514 02/18/08 04:26 AM
KiwiCowboy Offline
Hope it goes well for you and no leaks.
Re: Changing timing chain and gears, a little confused [Re: KiwiCowboy] #868515 02/18/08 02:55 PM
damitboy Offline OP
It seems to be running good so far. It is much quieter and I don't see any leaks yet. I've only driven short distances though.
Re: Changing timing chain and gears, a little confused [Re: Macka] #868516 02/21/08 07:50 AM
kerby2 Offline
I like your idea, when I used to manage a shop I gave the techs muffin pans. it helped in the order of take down as well. Excellent call on gloves as well. I clean my parts as well with a water based degreaser. It really helps with the satisfaction level after to see a clean job.
keith
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6114 MB (Peak: 0.6910 MB) Data Comp: Off Server Time: 2026-06-21 13:41:05 UTC
