Oil pan torque. #868846 02/13/08 03:32 AM
L
Littlewhitepup Offline OP
I have a 92 2.3 pickup with the 4ZD1 motor and I can't find the torque spec for the oil pan. I have seen things saying 13ft lbs but that is too much for it. I also seen things saying this motor is diff. than the other specs. Anyone know the correct spec?
Thanks
Re: Oil pan torque. [Re: Littlewhitepup] #868847 02/13/08 07:36 AM
lttlbddy Offline
This is out of a service manual for a 1990:
4 x 4 = 13ft lbs +- 3.6
4 x 2 = 3.6ft lbs +- .7
Re: Oil pan torque. [Re: lttlbddy] #868848 02/14/08 02:15 AM
L
That seems more correct. I will try it.
Re: Oil pan torque. [Re: Littlewhitepup] #868849 02/14/08 06:19 PM
HCMP Offline
Careful, they're easy to strip
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5988 MB (Peak: 0.6537 MB) Data Comp: Off Server Time: 2026-07-13 16:18:58 UTC
