adjusted the valves and retorqued the head = rough idle #868922 02/13/08 06:38 AM
trashcanman Offline OP
what gives I cant figure out what I did wrong. I adjusted the valves perfectly and then I did a retorque on the head bolts(it didnt need much). and when I went to start it, it seemed flooded after I cranked it over a couple of times( I could smell gas) so I mashed the pedal and it fired up, and after it settled down it idles rough. it doesnt seem like its running bad it revs fine just like someone turned down the idle alot. I only have 100 miles on the motor and Im freaking out. please help. its a 22re if that matters. how can it flood ints fuel injected? and what the hell is wrong with it?
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868923 02/13/08 04:55 PM
could it be that the vacuum of my engine being turned over twice for the valve adjustment, sucked in a bunch of gas from the injectors and when i started it, it fouled a spark plug?
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868924 02/13/08 05:04 PM
KiwiCowboy Offline
Sounds more like a vacuum hose came loose. Check for a loose,cut or smashed hose. BTW, you should torque the head bolts first then adjust the valves.
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868925 02/14/08 02:00 AM
missouriman Offline
sounds like you have your valves to tight.
check them again.
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868926 02/14/08 05:34 PM
yah I re-adjusted them. they were a little tight probably cause I retorqued the head after. It still idles rough though.
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868927 02/14/08 06:29 PM
missouriman Offline
well I hope that you didn't burn the valves.
these things tick a bit it is the nature of solid rocker/lifters.
look it up, I don't feel like it right now but there is a cold and a hot setting, if you set them to the hot setting (cold) they are to tight. the factory service manual specs are for hot.. I have never figured out how you are supposed to do it hot. with all you have to take off to get at them.
also double check your timing. and since you have the valve cover off get a flash light and check your timing chain guides, you can see them from the top. a very small telescoping mirror about the size of a dime, you will have to bend it a bit will give you a great view of them. oh use the mirror to direct the light vs using the mirror to see them.
also make sure that you didn't miss hooking up a vacuum line after pulling the valve cover.
let us know what you find.
Re: adjusted the valves and retorqued the head = rough idle [Re: missouriman] #868928 02/18/08 05:20 AM
willzrunna96 Offline
wow i havent posted on this site in 2 years..im sure some of you remember me...
but anyway...check you vaccuum line orientation...and recheck the intake valves to see if there not to tight....you will never get these motors dead quite...a little tapping is better than no tapping
Re: adjusted the valves and retorqued the head = rough idle [Re: trashcanman] #868929 02/18/08 02:47 PM
engnbldr Offline
>>>*Since snugging the headbolts would not have an effect, that can be discounted.
Adjusting the valves certainly could. The symptoms of a valve set too tight will be a rougher than normal idle.
If the ends of the adjuster screws are worn a bit this can make accurate adjustment difficult if not impossible.
There is also the chance something got bumped loose, a vac line, wire, etc....*EB
*Beats the he** outa me!....*LOL**...
Re: adjusted the valves and retorqued the head = rough idle [Re: engnbldr] #868930 03/07/08 06:31 PM
turns out it was a vacuum leak. mechanic said my valves were adjusted perfectly <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: adjusted the valves and retorqued the head = rough idle [Re: engnbldr] #868931 03/08/08 02:33 AM
missouriman Offline
YES, I have had the half moon wear on them, impossible to adjust them with that... even if you do get them adjusted the (end of the moon wears fast) and back to clicking.
I wished you lived next door. <img src="/forums/images/graemlins/smile.gif" alt="" />
oh and you are invited to the dakota territory challenge put on by the black hills 4 wheelers.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6389 MB (Peak: 0.7435 MB) Data Comp: Off Server Time: 2026-05-27 17:02:30 UTC
