hard starting #868937 02/13/08 03:35 PM
Crallsjeep Offline OP
I have a 96 with a 4.0, It has always started easily till yesterday morning. I cranked it for a long time, stopped, then on my re-try it started on the first grunt, at lunch the samething, and when I went home, again endless cranking, followed by a perfect start on the retry.
Any ideas?
Re: hard starting [Re: Crallsjeep] #868938 02/13/08 05:06 PM
Brown81CJ5 Offline
Turn the key to the on position, count to 10, then try starting the vehicle.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: hard starting [Re: Brown81CJ5] #868939 02/13/08 05:27 PM
Still cranks with out starting
Re: hard starting [Re: Crallsjeep] #868940 02/17/08 03:01 AM
Berkeley Offline
Jeep Moderator
Crank-but-no-start could be the CPS (or CPS connection) going bad. If there's spark, I'm wrong.
Try fiddling with the connection. IIRC, the CPS is on the top of the bell housing, driver's side. The connection should be accessible above that from the engine compartment near the firewall, left/port side.
Re: hard starting [Re: Berkeley] #868941 02/19/08 08:33 PM
Thanks for the reply,
she starts, and starts easily the second time. The first crank wont start the engine,
I have done a little research and see there is a vacumb fuel regulator. And it looks like I need a special fuel gauge to test this regulator. I would guess the pump is ok, and probably the fuel filter too, I have turned the key on for a brief period (letting the pump make pressure)before trying to start and there is no change, cranks the first time, starts the second time
Anyone had any expirence with this?
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6009 MB (Peak: 0.6643 MB) Data Comp: Off Server Time: 2026-10-26 11:12:58 UTC
