axles for a 1998 xj #869110 02/14/08 04:05 AM
hannibalxj Offline OP
I am trying to find out what year ford truck to be looking at to find dana 44 front and a ford 9 inch rear. must be the years that have a high pinion
Re: axles for a 1998 xj [Re: hannibalxj] #869111 02/17/08 03:22 AM
Macka Offline
Late 70's early 80's with 83-85 being the choice axles.
always working
Re: axles for a 1998 xj [Re: Macka] #869112 02/18/08 04:28 AM
the_other_guy Offline
I also have been looking for a dana 44 for my xj. would a dana 44 out of a 1977 ford work?
As long as the gears are the same, what else will I have to change other than the control arm mounts? will the d44 have the same lug pattern, and driveline yoke as the xj?
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: axles for a 1998 xj [Re: the_other_guy] #869113 02/24/08 07:19 AM
E
el_d_m Offline
a bud of mine did an axle swap with the rubicon front axle froma newer toybox. he is happy! but i know peeps that have taken the 9 inchers out of the laye 60"s bronco's & made them work pretty easily. there is a perfect 9 inch swap but extremely hard to find & thats out of a lincoln ( i forgot the name). its the ford granada body but the lincoln version of it. it has a 9 inch that is a very very good match & has disc brakes on it with ebrake.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: axles for a 1998 xj [Re: el_d_m] #869114 02/26/08 07:40 PM
F
fulltime79 Offline
are you thinking of the Zephur??
Re: axles for a 1998 xj [Re: fulltime79] #869115 02/27/08 02:36 AM
Bigbird79 Offline
The 9" with disc brakes was in the some years of the continental too.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: axles for a 1998 xj [Re: fulltime79] #869116 03/04/08 02:57 AM
E
el_d_m Offline
not the zephyr. Versailles thats the model i couldnt think of it. ty google. i used this axle in a swap it was easy.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6124 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-06-07 06:36:50 UTC
