Re: cant read codes ???? [Re: weel] #869203 02/15/08 02:42 PM
E
eleet Offline
J1850 VPW--The connector should have metallic contacts in pins 2, 4, 5, and 16, but not 10.
ISO 9141-2--The connector should have metallic contacts in pins 4, 5, 7, 15, and 16.
J1850 PWM--The connector should have metallic contacts in pins 2, 4, 5, 10, and 16.
If the vehicle is ISO9141 the K-line (7) should be at battery voltage when the bus is idle. I don't know about the other two.
Re: cant read codes ???? [Re: eleet] #869204 02/15/08 07:25 PM
Dandeman Offline
Toyota Moderator
I have a 97. It does NOT speak ISO9141. It speaks PWM - the Ford standard. This is very peculiar I think for Toyota.
You can tell by looking at the contacts installed in the OBD connector.
I knew early '96 Ts didn't use the ISO standard but wasn't aware of any '97s, let alone '98s that didn't use the ISO standard... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Guess best to verify by the pins in the connector as mentioned above..
Re: cant read codes ???? [Re: Dandeman] #869205 02/24/08 06:26 PM
W
weel Offline OP
Found a blown fuse. in the fuse box. i guess the power sigal goes thru there. now its pulling codes. misfire on cylinder 4 generic. i guess i need to check the plug wire and then the coil resistance will be next..
Re: cant read codes ???? [Re: weel] #869206 02/24/08 07:43 PM
BamZipPow Offline
Which fuse was it?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6088 MB (Peak: 0.6808 MB) Data Comp: Off Server Time: 2026-10-22 07:36:54 UTC
