Page 1 of 5 1 2 3 4 5
89 3,0L Starting Problem #869265 02/14/08 05:14 PM
PatrickS Offline OP
Starter works fine, new coil,distributor cap and rotor. Revsfor a second and then stops like the power was shut off. Then will turnover and no spark. Does anyone have any ideas?
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: 89 3,0L Starting Problem [Re: PatrickS] #869266 02/14/08 06:41 PM
It fires off, then dies? And won't fire off again for how long?
First guess is ecu capacitors, just 'cause so many have failed.
Re: 89 3,0L Starting Problem [Re: PatrickS] #869267 02/14/08 07:04 PM
8
89IsMine Offline
Huh. Kind of sounds like a fuel supply issue to me if it lights off for a second, then dies and just cranks on restart attempts. You're sure on the "no spark"? If you let it sit for a while will it go through the crank/light-off/die/crank-no-restart cycle again?
Eric W.
Re: 89 3,0L Starting Problem [Re: PatrickS] #869268 02/15/08 01:08 AM
conner Offline
Do you have power to the coil when there is no spark? If so, go to the distributor and check the four wires with key on and connector disconnected. You should see.
12v
ground
5v
5v
Both 5 volts should pulse to zero and back when cranked.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 89 3,0L Starting Problem [Re: PatrickS] #869269 02/15/08 05:16 AM
Grasscat Offline
I agree with Eddy. Pull the ECU and have a look. It's under the glove box.
Michael j
TreadLightly! Trainer
Re: 89 3,0L Starting Problem [Re: fasteddy] #869270 02/15/08 09:12 AM
PatrickS Offline OP
It does not fire off again for hours or the next day.
Re: 89 3,0L Starting Problem [Re: PatrickS] #869271 02/15/08 09:14 AM
PatrickS Offline OP
When I pull the ECU how can I check the capasitor
Re: 89 3,0L Starting Problem [Re: PatrickS] #869272 02/15/08 03:22 PM
hazy_daze Offline
Smells fishy.
Re: 89 3,0L Starting Problem [Re: PatrickS] #869273 02/15/08 04:28 PM
PatrickS Offline OP
I pulled the
ECU checked the capasitors for leakage or physical damage and could find nothing.
Re: 89 3,0L Starting Problem [Re: Grasscat] #869274 02/15/08 09:44 PM
PatrickS Offline OP
When cold, turn key to start and there is power to coil for very short time and then stops. As the key is turned off there is power to the coil for another instant.
When I have luck and it starts and runs, after warms up, then is no problem to shut off and restart.
Removed the ECU, all conections appear in order and no leakage at the capacitors.
Just before the coil there is another very small module. Is this also a capacitor?
Any Ideas?
(EDIT: ...added from second post)
89 3,0L Starting Problem Part 2
#1078734 - 02/15/08 05:20 AM (62.224.246.71)
Any Ideas?
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.015s) Memory: 0.6401 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-11-02 19:25:44 UTC
