Window Wipers #869310 02/14/08 06:30 PM
E
EyeOnCy Offline OP
I was hoping to get some feedback on this early and hopefully soon in case I get it all together and it doesn't work, but has anyone had a NON-ELECTRICAL problem w/ the front wipers? I could have sworn the motor went out, but got it tested and supposedly its good.
Is there a possibility that its weak?
The one sign that I think its something else is when I went to pull on the wiper arms to pull them thru their range of motion they're locked into place. This was AFTER I took the motor out. Anyways I got everything apart and am about to clean the whole assembly and reinstall everything after its good and greased. Anyone seen this before?
1989 Dodge Raider 2.6L/5spd
2004 Honda Element EX
1989 Dodge Daytona Shelby Z
1993 Toyota P/U
Re: Window Wipers [Re: EyeOnCy] #869311 02/14/08 06:38 PM
I've seen busted gearboxes and arm spindles frowen. Sometimes you get something jamming the underdash arms, like wiring harness or ductwork.
Re: Window Wipers [Re: fasteddy] #869312 02/14/08 08:33 PM
E
EyeOnCy Offline OP
Frozen joint, you got it Eddy! I was playing around w/ it and noticed that the main joint un the passenger side is frozen. Does anyone have one of these in good condition laying around? I also need a rear wiper motor.
Otherwise I guess I'll just wait a few weeks to go visit my fiance, know that junkyard has a couple up there.
1993 Toyota P/U
Re: Window Wipers [Re: EyeOnCy] #869313 02/16/08 10:22 PM
barlown Offline
i think i have on i'll let you know soon
88 montero 3'' body lift, torsion crank, shackles, 32'' tires 200,00 miles and going
Re: Window Wipers [Re: EyeOnCy] #869314 02/16/08 11:21 PM
Kevin C Offline
They all get stiff over time. I have put 3 in 1 oil on them with good results. They can be taken apart and cleaned up.
A drop of oil at the pivot point once in a while is good prevenitive maintenance.
Kevin
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6081 MB (Peak: 0.6724 MB) Data Comp: Off Server Time: 2026-11-17 11:29:09 UTC
