Ring and Pinion Gears fit?
#869334
02/14/08 10:27 PM
Will the ring and pinion gears from '92 Samari 372 ratio fit in a '95 geo tracker/sidekick which currently has a 513 ratio gear.
I need more speed for the RPMs as I just put a Isuzu Diesel in my Geo. Driveshaft has already been cut and fitted. Need to do a gear swap.
Re: Ring and Pinion Gears fit?
[Re: sparetire]
#869335
02/15/08 10:19 PM
sparetire try this forum- zukiworld.com i have no experience(yet)in gearing, but it seems a favorite subject, and seems like you could get good info. richard
'94 "tracker", with some parts from suzi the psychic. other modifications made, with more to come. some intentional. suzitoo should get me fishing. kj6esv
[Re: sparetire]
#869336
02/18/08 03:17 AM
The gears will fit the front diff, but not the rear. You can look for a set of 4.62:1 gears from another Track/Kick. Then front and rear diffs will just swap over without setting up the diffs again.
Bill ---------------------------- God Forgives, Rocks Don't...
[Re: Billjohn]
#869337
06/03/09 06:56 AM
I don't think they will at all. The front has a different diameter ring gear in the tracker, and the rear may be close to the Samurai, but there are two different gearsets used on the sidekick rear. One has the same bolt pattern (10 bolt, I believe) one a 12 bolt. The 10 bolt gearset is a mod for the Samurai, and I think an additional shim is placed behind the pinion gear to set depth properly in the Sami. So going the other way, the pinion might likely not be able to be set in deep enough.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6029 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-06-07 04:43:43 UTCValid HTML 5 and Valid CSS
