???which high steer??? #869406 02/15/08 07:00 AM
TOY84OTA Offline OP
After I get my tax return Im planning on doing a hysteer on my 84 pickup so im thinking of going with allpro or marlin cross-over kit and marlins steering box and stabilizer but im having trouble coosing the frame bracket its between marlin ant trail gear
http://www.marlincrawler.com/htm/steering.htm
http://www.trail-gear.com/images/ifsmount-600.jpg
which is a better x-over kit, any problems with ether one. Im thinking about allpro because of the come-moly steering arms and the tierod & drag link are above the springs, marlin has the tierod in the stock location
84 TOY P/U 35"Boggers 5"SUSPENTION 2"SHACKEL LIFT TRU-TRAC FRONT DETROIT REAR 5.29 GEARS COSTOM FABED BUMPERS & SLIDERS, MARLIN 4:70:1 CRAWLER T-CASE
Re: ???which high steer??? [Re: TOY84OTA] #869407 02/15/08 07:36 AM
4Crawler Offline
All the HySteer kits will have the tie rod over the springs, that is what High Steer is, placing the tie rod high above the stock location. Not sure anyone is making a low steer crossover kit any more. I've run a number of All Pro kits over the years, they have all worked well. Marlin and Trail Gear are also supposed to be good and I originally ran a Marlin heavy duty tie rod and it worked great. Suppose you pick the features you want that fit within your budget and go with that.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5887 MB (Peak: 0.6372 MB) Data Comp: Off Server Time: 2026-11-04 20:50:12 UTC
