obd2 question #869473 02/15/08 07:57 PM
montyjo Offline OP
I read a post that stated that the 95 Montero SR had uses OBD2. Can anyone comfrim this?
1995 Montero SR
SuperWinch Hubs, 31x10.5 BFG A/T'S
Re: obd2 question [Re: montyjo] #869474 02/15/08 08:06 PM
Actually I think on mitsu's OBDII compliance started in 96.
Re: obd2 question [Re: montyjo] #869475 02/15/08 09:01 PM
Yes, the 95 and 96 ECU is the same part #. Although I have not had luck in getting my freeware scanner to work though.
Re: obd2 question [Re: OldColt] #869476 02/15/08 09:17 PM
montyjo Offline OP
Thanks for the replies. If the ECU is the same as a 96, then shouldn't I be able to read the error code with a OBDII scanner? And where is the plug located?
1995 Montero SR
Re: obd2 question [Re: montyjo] #869477 02/17/08 02:51 PM
conner Offline
The 95 is not OBDll complaint. Look at your underhood sticker.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: obd2 question [Re: conner] #869478 02/17/08 10:05 PM
OBD II was not required in 95 therefore no sticker would be applied. The diagnostics scan the same for 95 and 96.
Re: obd2 question [Re: OldColt] #869479 02/18/08 01:36 PM
montyjo Offline OP
I found the obd2 plug down by the foot rest. I just haven't had the time to get a scanner. Maybe I'll take it to AutoZone tonight, let them try to scan it. The check engine light has been coming on lately. We don't drive the montero much any more, I think its getting lonly. <img src="/forums/images/graemlins/lol.gif" alt="" />
1995 Montero SR
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.017s) Memory: 0.6197 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-11-04 20:02:09 UTC
