How much boost is safe??? #869969 02/18/08 08:47 PM
david85 Offline OP
How high have you pushed your diesels? Also, do any of you know if there are any stronger head bolts available for this engine (4D55/56)?
I have a big ford/international powered diesel truck and ARP has an off the shelf kit for that engine, but I can't find anything for the mitsubishi duesels.
Re: How much boost is safe??? [Re: david85] #869970 02/18/08 09:53 PM
torquemonster Offline
you can run 20lbs. make sure you crank the pump though as you will lean it out.
Re: How much boost is safe??? [Re: torquemonster] #869971 02/19/08 04:05 AM
david85 Offline OP
Thanks for the info.....but diesels don't run a fixed mixture ratio, so what is the harm in running lean??
Re: How much boost is safe??? [Re: david85] #869972 02/19/08 05:46 AM
redbull Offline
Not really any harm, but you won't make any more power with all that extra air if you don't add fuel.
Good read on diesels:
http://www.diesel-central.com/News/cackle.htm
Re: How much boost is safe??? [Re: redbull] #869973 02/19/08 07:10 AM
more fuel+more air=more power...simple
Re: How much boost is safe??? [Re: torquemonster] #869974 02/19/08 09:02 PM
david85 Offline OP
Aahh, OK. I thought you meant it could harm the engine from running lean, which I know not to be the case with diesels. I've been driving/modding diesels for most of my driving life now. Theres something about that rattle <img src="/forums/images/graemlins/kewl.gif" alt="" />.
So I guess there are no options for stronger head bolts then?
Re: How much boost is safe??? [Re: david85] #869975 02/19/08 10:34 PM
redbull Offline
Have you contacted ARP?
Re: How much boost is safe??? [Re: redbull] #869976 02/20/08 04:14 AM
david85 Offline OP
Tried Emailing, but got no reply. Their list of engine head bolt/stud kits mentions nothing about the 4D55/56 diesel engines. My feeling is that there is a stud that they make that would fit, but finding it would involve cross referencing the application based on the type of stem instead of part number. Its very rare that anyone with access to the part numbers is willing to do that leg work for you. So for now, I'll probably have to reuse the old bolts.
Re: How much boost is safe??? [Re: david85] #869977 02/20/08 04:30 AM
redbull Offline
I'd phone them. 800 number - nothing to lose.
1863 Eastman Avenue
Ventura, CA 93003
Hours: 7:30am - 4:30 pm PST
email: info@arpfasteners.com
Order Desk & Technical Support: 800.826.3045 or 805.339.2200, fax: 805.650.0742
Sales & Marketing: 800.826.3045
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6246 MB (Peak: 0.7107 MB) Data Comp: Off Server Time: 2026-11-18 03:43:59 UTC
