22RE Idle Adjusting Screw Gone Wild #870161 02/19/08 06:33 AM
matts Offline OP
The idle adjusting screw on my '88 22RE throttle body works itself into low, low idle settings in a about 15 minutes of driving lately. It also seems turned pretty far out (the top of the screw is flush with the top of the bore it screws into.). It actually tightens down by itself as I drive until it won't idle. Maybe the idle air bypass passage is choked off with dirty gunk requiring the screw to be backed off too far. Anybody ever seen anything like this? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: 22RE Idle Adjusting Screw Gone Wild [Re: matts] #870162 02/19/08 02:17 PM
grandeyota Offline
So I'm not the only one this is happening to then. Whew <img src="/forums/images/graemlins/lol.gif" alt="" />
My idle screw decides to tighten itself as well. I guess thats better than it going the other way and falling out.
1990 22re
Fur clog in the sausage grinder
Re: 22RE Idle Adjusting Screw Gone Wild [Re: grandeyota] #870163 02/20/08 01:38 AM
Bogo Offline
Not having had to mess with one yet, what does the head of the idle screw look like? It may be possible to use a wire or piece of metal to hold it so it doesn't turn. Often bolts and screws on aircraft have holes in the head so a wire can be threaded through to keep it from loosening. Knurled knobs lend themselves to having spring steel edges pressed against them to keep them from turning. Screwdriver slots can also have spring steel pieces fashioned to keep them from turning.
-- Bryan
Re: 22RE Idle Adjusting Screw Gone Wild [Re: Bogo] #870164 02/20/08 03:02 AM
matts Offline OP
It is a large diameter screw with a slotted head. Should be easy to use a spring wire to "stake" it like you describe. I'd still like to hear from somebody who knows why this happens. -- Matt
Re: 22RE Idle Adjusting Screw Gone Wild [Re: matts] #870165 02/20/08 08:40 AM
Frank Torres Offline
Use a bit Teflon tape on the threads and or replace the o ring on the screw....
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: 22RE Idle Adjusting Screw Gone Wild [Re: Frank Torres] #870166 02/20/08 01:04 PM
subliminaltrips Offline
i too was going to suggest teflon tape
Re: 22RE Idle Adjusting Screw Gone Wild [Re: Frank Torres] #870167 03/11/08 04:04 AM
matts Offline OP
Man! I am really guilty of taking the lazy approach to this problem. I finally removed the screw to inspect it and sure enough it has an o-ring in a groove on the thick upper body of the screw. The o-ring on this one is junk so it doesn't seal and make enough friction to hold the screw from vibrating out of position. I had a little pipe dope handy so I goobered up the threads and now it holds fine. I'll look for the correct o-ring tomorrow and do it up right. -- Matt
Re: 22RE Idle Adjusting Screw Gone Wild [Re: matts] #870168 03/11/08 08:32 AM
suba Offline
Hmm, my 4runner idles right at 750 (adjusted timing and idle screw today in fact, then drove about 80 miles) with the screw about flush with the top. i can't remember what my truck was set at (same year, 86) but i seem to remember the same scenario for screw position roughly. I'll look at it tomorrow to verify.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6225 MB (Peak: 0.7053 MB) Data Comp: Off Server Time: 2026-10-22 07:36:43 UTC
