Clutch pedal noise #870183 02/19/08 02:59 PM
damitboy Offline OP
My next fix is an annoying noise and feel I get from my clutch pedal only after it warms up. I get this loud "creak-creak" sound when pressing in and on the release. It only does this after it heats up to operating temp. It also feels a little sticky or spongy but only when heated up. Again, it feels and sounds normal when cold. It also does the creak-creak noise with the engine shut down after it's heated up. Could it need bleeding, or a new bushing in the pedal mechanism? Any suggestions? Thanks in advance.
94 XJ 2 Door/2.5/5 SPD/4 WD
Re: Clutch pedal noise [Re: damitboy] #870184 02/19/08 03:34 PM
BigJim Offline
Same noise when NOT RUNNING? Means loose bolts or return spring noise. A little attention should fix the noise.
On the other hand a squeak while running only means clutch bearing is dry or worn.. Only replace with complete clutch kit.
Re: Clutch pedal noise [Re: BigJim] #870185 02/19/08 06:29 PM
damitboy Offline OP
Do you mean in the pedal mechanism or the internals?
Re: Clutch pedal noise [Re: damitboy] #870186 02/19/08 08:52 PM
BigJim Offline
Damnit boy! I don't know another way to say it! If it makes the noise while the engine isn't running it prolly is in the LINKAGE before the clutch.. Maybe under your dash.
Re: Clutch pedal noise [Re: BigJim] #870187 02/20/08 07:42 PM
damitboy Offline OP
I did the best kind of yoga I know how and laid underneath and reached around with the tip of my finger and barely pressed the pedal and the sound does seem to be coming from inside the bell housing. Not 100% sure though.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-06-17 02:56:17 UTC
