when i conect battery posts engie wants to start no key in? #870344 02/20/08 12:33 AM
blackmage Offline OP
it looks like someone wired its there way the battery drains its self within a day. When i put on the posts the right side of engine makes a little grind i really don't know how else to explain it
Re: when i conect battery posts engie wants to start no key in? [Re: blackmage] #870345 02/20/08 01:15 AM
You obviously are experiencing the symptoms of a high-tension draw. I'd look into the possibility of the starter switch on the steering column not following the same synch as the ignition key.
Re: when i conect battery posts engie wants to start no key in? [Re: blackmage] #870346 02/20/08 01:17 AM
looks like it was rewired and i can't figure out which line is live taking ll my battery juice
noticed my idle does a up and down sort of thing this is my first car and I've had a hell of time trying to figure out everything the past 2 years putting what i can into it
what you said to me makes like no sense il read the manual i got
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5947 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-17 13:25:43 UTC
