tranny swap #870644 02/22/08 01:44 AM
mqm Offline OP
89 ext 4x4 pickup 22re w56 140k
My w56 transmission started making some rattling noises on occassion, definately coming from inside the transmission housing. Oil level is full. Came across a pretty good deal for a transmission out of a 93 4x4 v6 model toyota pickup. Initially transmission looks pretty much the same except for the transfer case and cover underneath the shifter has 4 bolts to the transmission as opposed to a 6 bolt cover plate under the shifter of my w56. Is it possible to make this swap? Can i bolt up my gear driven transfer case to the v6 (r150 i think) tranny?
Re: tranny swap [Re: mqm] #870645 02/22/08 03:41 AM
4Crawler Offline
Would likely require an R151 bellhousing (22RE turbo tranny) and an adapter plate for the t-case.
Re: tranny swap [Re: 4Crawler] #870646 02/22/08 04:47 PM
mqm Offline OP
Is there a difference between the sline shafts of the w56, r151f and the r150??
Re: tranny swap [Re: mqm] #870647 03/01/08 03:22 AM
mqm Offline OP
found a r151 tranny out of a turbo 22re 4x4. Will i have to modify anything to make this fit in place of my w56?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6003 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-07-15 07:16:54 UTC
