22re Won't Start #870751 02/22/08 11:50 PM
G
GOI87 Offline OP
I just got done replacing the Head Gasket and finished hooking everything back up. I was VERY carfull to keep everything on TDC. It ran when I tore it down, now nothing. I put the crank at 12:00 and the cam at 12:00 then put the distrubutor at #1. I've done this 3x now and it has been correct all 3x. I've found out that if I mash the gas pedal to the flool the truck eventually "starts", It's really rough and quickly dies. It backfired at me so I stopped tring to diagnose it that way. This is really making me mad. The timming is close enough then it should at least run. My dad said that the first time he went to start it, it ran for 30 sec. but it stopped. We haven't been able to start it since, it just spins. All of the lines are hooked up.
Any thoughts!
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: 22re Won't Start [Re: GOI87] #870752 02/23/08 12:01 AM
4Crawler Offline
Make sure there are no cracks or holes in the air intake tubing, double check all the rubber bellows sections especially.
Then you can try the fuel pump test jumper to see if that helps:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: 22re Won't Start [Re: 4Crawler] #870753 02/23/08 12:36 AM
G
GOI87 Offline OP
Thanks 4Crawler-your rapid replies are always welcome and appreciated. <img src="/forums/images/graemlins/patriot.gif" alt="" /> I got it started and it would run as long as you gave it gas. With constant throttle, the rpms would flux. We're going to try adjusting the valves to see if that helps. What were the cold set specs again. .008 and .01? I always forget?
Re: 22re Won't Start [Re: GOI87] #870754 02/23/08 02:55 AM
1
1986xtracab Offline
I believe it was hot .008 and .012 , I think.
1986 xtra-cab 22re
stock everything
1991 bed
Re: 22re Won't Start [Re: 1986xtracab] #870755 02/26/08 06:26 PM
G
GOI87 Offline OP
thanks,
Well, my Luck ran out. I pulled the valve cover to find that 2 intake valves were stuck in the down possition. I tried to tap them up to see if they would "pop" back up, but I think they already got bent with the piston. So off comes the head and back to the head shop for repair. <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" />
Does anyone know why the valve would just stick? <img src="/forums/images/graemlins/confused.gif" alt="" /> The only thing I can think of is that there was NO oil for it to run with. So when it ran for the 30 or so seconds there was no lube and they overheated and seased, then got smacked by the piston. other than that I have no Idea <img src="/forums/images/graemlins/zombie.gif" alt="" /> Does this happen more often than not or did I do something wrong or do I really have bad luck? after I pulled the cover, there was oil on everything on the head, cam, rockers, valves. But that isn't to say it got up there after the damage already happened.
Re: 22re Won't Start [Re: GOI87] #870756 03/06/08 11:23 PM
G
GOI87 Offline OP
I still don't know how I bent 2 valves. I KNOW that everything was installed correctly. TDC with cam @ 12:00. Has anyone else done this? Or have any suggestions? What could have went wrong on the install? Could the rocker assembly be warped somehow or misalign while torquing the head down?
HELP...Need to know what not to do!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6153 MB (Peak: 0.7022 MB) Data Comp: Off Server Time: 2026-05-29 19:51:31 UTC
