93 Grand Cherokee 4.0 trouble starting in cold weather #870757 02/23/08 12:09 AM
P
pete1950 Offline OP
My 93 4.0 Has a real hard time starting in cold weather. Is there a cold start sensor I can check?
Re: 93 Grand Cherokee 4.0 trouble starting in cold weather [Re: pete1950] #870758 02/23/08 09:10 PM
fresnodb Offline
Welcome to the forum. Your question has to many variables. Cold weather out here in Cen Cal this time of year is mid 40s. Is the problem when the vehicle is cold as in ovrernight but starts ok when it is warm? Does it crank OK but seem like it's not getting fuel? If you hold the throttle slightly open, does it start OK?
Back in the game!
'94 YJ 2.5 all stock.
Re: 93 Grand Cherokee 4.0 trouble starting in cold weather [Re: fresnodb] #870759 02/24/08 02:20 AM
P
pete1950 Offline OP
i live in upstate New york. It starts if I pump the gas pedal while cranking. Temps here have been in the single digits.if the temps are above freezing it starts much better. It starts fine when warm.Thanks for the warm welcome and the reply.
Re: 93 Grand Cherokee 4.0 trouble starting in cold weather [Re: pete1950] #870760 02/24/08 02:49 AM
Brown81CJ5 Offline
Sounds like you might want to get an engine block heater or something of the sort.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 93 Grand Cherokee 4.0 trouble starting in cold weather [Re: Brown81CJ5] #870761 02/24/08 03:04 AM
BigJim Offline
Pete Pumping the pedal on a fuelie only serves to confuse the computer... Instead try cracking the pedal 1/4" or LESS and see if it starts quicker.. A SMALL amount might help but pumping does nothing good for starting.
Also try turning the key to the run position to build up fuel pressure before hitting the start position.
Re: 93 Grand Cherokee 4.0 trouble starting in cold weather [Re: BigJim] #870762 02/24/08 05:02 AM
P
pete1950 Offline OP
I'll try that in the am and post back.
Pete
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6106 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-05-29 14:37:50 UTC
