thinking of buying an amigo #870828 02/23/08 01:58 PM
jbanderson Offline OP
My wife wants a small SUV, and after looking at pretty much everything out there. I really like the Amigos.
I need someting that can tow my ski boat that is about 2500-3000lbs. I read that the towing capacity is 4500 with the V6 so that shouldnt be a problem.
I have found a 2000 V6 4x4 auto with 70K miles on it for $7,000 This thing is PERFECT on the outside and in. I am a mechanic and can check things out but is there anything I should pay special attention to? Any major problem areas?
Thanks alot
Re: thinking of buying an amigo [Re: jbanderson] #870829 02/23/08 04:20 PM
Moonhole Offline
I just bought a 2001 V6, Auto , 4WD with 108K for $6100, so that sounds like a good deal. The one thing I read about was oil consumption because of a piston ring problem that was corrected in 2002 (new design has a PCV that screws in not push in). So far, 800 miles that I have owned it, no oil problems yet. I changed all the fluids (front diff was almost dry) and bought a timing belt kit I haven't installed yet. Good luck!
87 Trooper II
01 Rodeo Sport
Re: thinking of buying an amigo [Re: jbanderson] #870830 02/23/08 07:12 PM
TrooperII Offline
have a 99 V6, put 40,000 on it so far. Have the oil consumption problem (Just keep your eye on the oil level) , the fuel gauge problem. it don't work half the time, but you can fix it with a new sending unit. Also had a starting problem shortly after we bought it. It would start, but you had to crank on it for a while. Found out it was a sensor from one of the sites. Don't remember which one. But when I replaced it, it started right up. I cranked the torsion bars up and now I have a Half shaft problem, but thats my falt. Not the amigos. I love the truck. lots of fun in the warm months.
85 2.3 Woods Trooper (bye bye 1.9)
89 2.6 RS (really short)x2
94 Amigo
86 Troopers x2
Its really an addiction
Re: thinking of buying an amigo [Re: TrooperII] #870831 02/23/08 09:19 PM
TrailMystic Offline
Don't forget the leaky intake manifold gasket issue <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Also, keep in mind that this vehicle may look smaller, but it is heavy. Don't plan on more than 20 mpg highway.
Overall, however, the issues are not major. It is a great truck and I plan to keep mine for the rest of my life. Keep plenty of oil in it and it will run 250,000 miles or more.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: thinking of buying an amigo [Re: TrailMystic] #870832 02/24/08 07:45 AM
cool thanks.
Now how about lifting? I think a 3" body lift 2" torsion bar crank and 2" rear springs would fit 32's or 33's?
Re: thinking of buying an amigo [Re: jbanderson] #870833 02/24/08 02:40 PM
A
Amigo-2k Offline
I have a 2000 v6 2wd with 83k (original owner). The intake manifold gasket has gone out 2x (under warranty). The rear brakes were replaced at 75k. Other then normal stuff, fluid, filters, s-belts and getting use to the drive-line thump due to drive shaft design I have seen no issues (22 MPG on the highway; no oil usage issues).
Re: thinking of buying an amigo [Re: jbanderson] #870834 02/25/08 06:07 PM
HCMP Offline
Timing belt was due at 60k but most people replacing them at that mileage have reported the belts to be in great shape. I replaced mine at 110k and it was in good shape. Also the 3.2 is a non-intereference.
Keep in mind that while it'll tow that weight without a problem it may not be as comfortable as a longer wheelbase vehicle.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6210 MB (Peak: 0.6957 MB) Data Comp: Off Server Time: 2026-06-07 03:14:12 UTC
