BIG crack in PS exhaust manifold '99 MS
#871341
02/25/08 02:57 PM
I've had my '99 Sport 3.5L for about 2-1/2 mo now. Been working out the bugs little by little. Not long after I bought it I noticed a slight popping in the exhaust tone somewhere up front but figured it was just a small leak at a flange or something. After reading that exhaust manifold cracks are common in some of the later models I decided to have a look.
The PS manifold is severely cracked (possibly a complete fracture) between the rear and middle cylinder.
I assume it's not going to cause any additional problems to drive it like this for a few weeks while I line up a replacement, but I'm curious - I've been getting TERRIBLE mileage - I've seen it below 13 a few times. Could a crack that size effect mileage noticably? It does so-so if it's 100% highway. We got right about 17 ONCE.
I'm not certain what parts interchange. By mitsupart's description I can use any 3.5 OR 3.0 manifold '97-03. Sound right?
 Dec '07 purchase -- '99 Sport LTD 3.5L SOHC - 139k, now 188k '95 Montero LS 206k+ (traded) New DD - '99 Taurus SHO 95k - V8's are fun <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: BIG crack in PS exhaust manifold '99 MS
[Re: Liquid_force]
#871342
02/25/08 03:09 PM
Could a crack that size effect mileage noticably? Yes. Extra air enters the exhaust manifold and the o2 sensor reads it as a lean condition. The ECU takes the bogus signal from the sensor and tries to correct by adding fuel. Overly rich mixtures can damage/plug catalytic converters, so it's possible you will need to replace yours. I wouldn't automatically condemn yours, but be aware of the possibility. Frank
[Re: FrankR]
#871343
02/25/08 03:33 PM
Frank That makes sense. It has a bit of a stumble every few seconds at idle. Similar to what my old 2.3L Turbo Ford did when the FPR failed and was flowing way too much gas.
[Re: FrankR]
#871344
02/25/08 06:12 PM
hmm, that could also explain why i've been getting horrible gas mileage, even on the highway. I did add a tad bit more air in the tires, but only cuase it was low. That helped, but I still only average 13-14mpg, and thats on the highway.
At first I thought it was a heat shield cause of quick vibrating noise from underneath. But I'm gonna be doing some work to the Monty here soon so I'll have that checked off the list soon.
Just never thought that would mess with the gas mileage.
[Re: Angelo]
#871345
02/26/08 02:54 AM
I still only average 13-14mpg, and thats on the highway <img src="/forums/images/graemlins/frown.gif" alt="" /> Thats bad. Even with my cargo box and ski rack on the roof I still get 18-19 highway and 14-15 city.
92 Galant vr4 11.17at132mph 98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels. trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
[Re: Liquid_force]
#871346
02/26/08 05:25 AM
I don't know if it's a actual design issue but that's exactly where both mine cracked. I guess if it helps I ran mine for six or seven years with at LEAST one cracked and other than the stumble you're describing and slight decrease in gas milliage it ran. Noisy, but it ran.:-)
The dealership and a couple other people I've talked to say that our exhaust manifolds don't respond well to being dunked and having cold water splashed on them when they're hot. Guys at the shop say they replace several a year on just street driven vehicles.
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: ES_97Sport]
#871347
02/26/08 07:27 PM
That explains my running rich problem, and I though it was the carb. Well Mikuni is somewhat troublesome but I cannot complain about mine BUT on my last smog test with a new catalytic converter it read 768 when the allowed is 1,2xx. I took it to this Japanese auto repair shop thinking the cab needed a little fine tuning, I think it does, and the Japanese dude said, "I don't know anything about carburetors" <img src="/forums/images/graemlins/zombie.gif" alt="" /> He just swap motors and that's it.
Hell, I can do that.. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
